5G SA on mmWave n257 UE camps but never transmits UL (no PRACH / no random access)
In an RG530F-EU module we are trying to attach in 5G Standalone (SA) to a private mmWave n257 (28 GHz band, TDD) cell. The module camps on the cell and reads SSB/SIB1 (LIMSRV), but never transmits any uplinkAT+QNWCFG="nr5g_tx_pwr" stays 0 the whole time, so the module never sends a PRACH / never initiates random access, and therefore never registers or establishes a PDU session. The same module and SIM register and work fine on n78 (FR1) SA.
This matches your forum threads [#55114] and [#40155]: n257 SA is not enabled in the RG530F-EU firmware (n257 is supported in NSA only) and requires a Quectel-provided MBN profile + FR2-SA configuration/firmware to unlock.
We are requesting:
  1. The FR2 SA MBN profile and any firmware required to enable n257 (and/or n261) 5G SA on RG530F-EU for our firmware version.
  2. The FR2 SA Application Note for RG530F.
  3. Confirmation of which mmWave bands (n257 / n258 / n260 / n261) are supported for SA (standalone) vs NSA on this module, and the correct provisioning steps.
2. Module / firmware
ATI:
RG530F-EU
Revision: RG530FEUEAR05A02M8G
  • Variant: RG530F-EU
  • Connection: USB, MBIM mode (wwan), AT port /dev/ttyUSB2
  • SIM: test SIM, IMSI 001010000012257, PLMN 001/01 (private network)
3. Network under test
  • Private 5G SA network, band n257, TDD, SCS 120 kHz, 100/200 MHz.
  • SSB @ ARFCN 2065051 (27.153 GHz); also tried ARFCN 2079739 (28.034 GHz).
  • gNB: OpenAirInterface (OAI) + O-RAN 7.2 mmWave O-RU. 5GC: OAI/Open5GS.
  • The same gNB/UE/SIM on n78 (FR1) SA registers successfully (see §5), so the SA core, SIM provisioning and the module’s SA/TX chain are all functional — the problem is specific to n257 SA uplink.
4. UE configuration applied (per your FR2 setup guidance)
AT+QMMWENABLE=1                                 -> OK  (mmWave front-end enabled)
AT+QNWPREFCFG="mode_pref",NR5G -> OK (NR5G only / SA)
at+qnvfw="/nv/item_files/modem/nr5g/RRC/fr2sa_enabled",01 -> OK
AT+QNWPREFCFG="nr5g_band",257 -> OK (accepted; no CME ERROR)
AT+QNWPREFCFG="nr5g_disable_mode",0 -> OK (SA+NSA)
AT+QMBNCFG="autosel",0 -> OK
AT+QMBNCFG="select","ROW_Commercial" -> OK
AT+CGDCONT=1,"IPV4V6","oai" -> OK
AT+CFUN=1,1 (hard reset)
Capability report:
AT+QNWPREFCFG="ue_capability_band"
+QNWPREFCFG: "nsa_nr5g_band",1:3:5:7:8:20:28:38:40:41:75:76:77:78:257:258:260:261
+QNWPREFCFG: "nr5g_band",257
(n257/n258/n260/n261 all listed under nsa_nr5g_band.)
5. Observed behaviour
On n257 (FR2) — FAILS: camps but never transmits UL
While the gNB is transmitting and the module is camped, polling every ~2 s:
state=LIMSRV  RSRP=-65 dBm   AT+QNWCFG="nr5g_tx_pwr" -> 0
state=LIMSRV RSRP=-70 dBm AT+QNWCFG="nr5g_tx_pwr" -> 0
state=LIMSRV RSRP=-77 dBm AT+QNWCFG="nr5g_tx_pwr" -> 0
... (nr5g_tx_pwr = 0 for the entire session, at all RSRP levels)
AT+C5GREG? -> +C5GREG: 0,2 (searching / not registered)
AT+QENG="servingcell"
+QENG: "servingcell","LIMSRV","NR5G-SA","TDD",001,01,000000001,0,1,2065051,257,13,-65,-11,...
AT+CGPADDR=1 -> +CGPADDR: 1,"0.0.0.0" (no PDU / no IP)
  • The module camps on the correct NR5G-SA cell (PLMN 001/01, ARFCN 2065051, band 257) and reports good RSRP (down to −58/−65 dBm), but stays in LIMSRV (limited service).
  • nr5g_tx_pwr = 0 at all times → the module never keys the UL transmitter → no PRACH.
  • gNB confirms: no PRACH preamble is ever received (UL is at the thermal-noise floor whether the module radio is ON or OFF), i.e. the module is not transmitting Msg1.
  • Result: no random access → no registration → no PDU session → no IP.
On n78 (FR1) — WORKS
Same module + SIM + core on band n78 (sub-6 GHz) SA: Registration Complete, UE reaches 5GMM-REGISTERED at the 5GC. So SA registration and the module’s UL transmit path work — the failure is confined to n257 SA uplink.
6. Our interpretation (please confirm)
The RG530F-EU firmware (RG530FEUEAR05A02M8G) appears to enable n257 in NSA only; in SA the module camps for limited service but will not initiate random access on n257 (uplink stays disabled, nr5g_tx_pwr=0). This is consistent with forum threads #55114 and #40155, where Quectel indicated an MBN profile + FR2-SA files/firmware are required to enable n257 SA.
7. Questions
  1. Is n257 5G SA supported on RG530F-EU with firmware RG530FEUEAR05A02M8G? If not, which firmware version enables it, and can you provide it?
  2. Please provide the FR2 SA MBN profile (and the FR2 SA Application Note) to enable n257 (and/or n261) SA uplink on this module/firmware.
  3. Which mmWave bands are supported for SA vs NSA on RG530F-EU? Is n261 (US 28 GHz) SA-capable out of the box, as an alternative to n257?
  4. Are there additional NV items / AT settings (beyond fr2sa_enabled=01, mode_pref=NR5G, nr5g_band, nr5g_disable_mode=0) required to make the module perform SA random access on mmWave?
Dear @baenaedu
I have sent newer version to your email, please check.
For limited service, do you confirm your SIM card support mmwave? or the network support mmwave SA?
