5G NSA Slicing problem with Quectel RM500Q
Dear all,
I’m trying to make slicing in a NSA 5G network work, but I haven’t gotten past the AT+CGDCONT command. I believe the format is correct, but I’m concerned that once the NSA connection is established, you won’t be able to configure the slicing because you may also receive an LTE connection. Due to my home network, I’m only able to get E-UTRAN-NR dual connectivity.
Is it possible to configure S-NSSAI using this access technology? Does anybody know how to configure the module in order to prioritize NR connected to 5GCN or NG-RAN access technology? (These ones I’m sure they allow slicing)
The command used to define PDP Contexts for slicing:
AT+CGDCONT=7,“IP”,“NSSAI”, “0.0.0.0”,“01.000000”
FW:Revision: RM500QGLABR11A06M4G
Thanks a lot !
Hi, I think this link may help you:
