Hi!
I been trying to find a reliable soft router firewall or a mini pc with real port support for 5G modules.
Mostly out there the ones with 2 pcie ports are frequently only valid to use with hdd, so not valid for a modem with pcie m.2 adaptor.
I just wonder if any of you is running and without issues your 5G module with this devices to avoid depending of a RGMII board?
What devices are you using or recommend?
Any of you is running the RGMII boards connected to this diy firewalls often running Opnsense, or many you can install as well Openwrt?
#soft router #firewall 5g #diyrouter
