I need LTE signal quality reports such as “RSRP/RSRQ/SINR” on EC25 and EC200T Modules but i can have only RSSR by using “AT+CSQ” command.
Does Any one know have i can get this parameters?
thank you
is there a possibility to see on which antenna port the antenna is connected (Main or Div) or is it possible to see the receive signal strenght for both Main and Div ports?
The AT+QRSRP command gives a figure for RSRP on all antenna ports.
The command AT+QRSRP is not supported on my EG25G module. Is there a special fw required
