I need to turn on 3G on my SC20 board. Does it exist some software like wpa_supplicant for the 3G setting? Let me clarify what I mean. I turn on a 3G connection using a touchscreen now. But I need to do it from the console or using a bash-script. Moreover “systemctl” command show me QCMAP_ConnectionManagerd.service - loaded active running. Maybe I can connect to the network using QCMAP_CLI? Please clarify.
Dear customer:
We don’t have this command to do this work. Any change by AT command will not take effect.
But i think you can try to write a Android service to do this work.
you can refer to Settings application,
Hello, I have the exactly same issue, we are developing our own board based on the SC20, our board doesn’t have a screen and we need that the board connects automatically to the 4G network.
There is a configuration file?
Could you make a new post for your question?
We will let our fellows focus on your issue specifically.
Because Jax had left our department, I will invite a new fellow to help you if you make a new post.
Hi Job
I found the configuration file, now is working.
Jose
