25-EUX stuck in FTM mode (CFUN:5) after firmware update failure, need QCN restore
Hello Quectel Support,
During a firmware update of my EC25-EUX module, there was an unexpected power failure which corrupted the module’s firmware. I had to recover it via EDL mode using QFirehose, but unfortunately the NV/QCN data (RF calibration) was lost in the process.
Now the module is stuck in Factory Test Mode and cannot connect to any network.
Current status:
  • AT+CFUN? returns +CFUN: 5
  • AT+CFUN=1 returns +CME ERROR: 3
  • AT+CSQ returns +CSQ: 99,99
  • AT+CREG? returns +CREG: 0,0
  • AT+CPIN? returns +CPIN: READY
  • RF NV items appear to be completely empty
Module details:
  • Model: EC25-EUX
  • Revision: EC25EUXGAR08A09M1G
  • Serial Number: MPY24FM2R006763
  • IMEI: 867395075101903 (restored via AT+EGMR after recovery)
  • Current firmware: EC25EUXGAR08A15M1G_20.200.20.200
  • Host device: Teltonika RUT956
I have tried:
  • AT+QNVFW="/nv/item_files/modem/mmode/cmph/ftm",00 - returns OK but CFUN stays at 5 after reboot
  • AT+QNVFW="/nv/item_files/conf/multisim_ftm_mode",00 - returns OK but no effect
  • AT+QPRTPARA=3 - returns ERROR
  • Multiple firmware versions flashed - same result
Could you please provide a QCN backup file or RF NV calibration data for this module (or a generic one for EC25-EUX) so I can restore it to normal operation?
Thank you in advance for your help.
Thank you for the detailed information.
Based on your description, the module has lost its RF NV (calibration) data after recovery, and is now stuck in Factory Test Mode (CFUN: 5). This is consistent with the observed behavior such as no signal (+CSQ: 99,99) and inability to return to normal functionality.
Kindly note that the RF NV/QCN calibration data is factory-specific and unique to each module. It is generated during production calibration and is not interchangeable between modules. Therefore, we are unable to provide a generic or replacement QCN file for recovery.
