Zero Byte Sessions created in Cellular Network without data transfer
We are using Quectel BC660K Module for one of our project.
The normal workflow is as below,
The Device registers with network for 1st connect & then later on it enters into PSM.
And then the device keeps existing from PSM, transmits the data & enters back into PSM.
The Data transfer is once in a day & and rest period it remains in PSM.
If due to any reason, at the wakeup if operator is not available or the IP context/IP address is not available, then the device tries to re-register on the network & completes the Data transfer after successful registration.
During this, we have observed that there are cases, where the device is creating a session on Cellular Network, but no data transfer is done.
The logs from Cellular Network Provider & also the Wire Shark logs captured by Cellular Provider as attached
0_byte_logs.zip (18.0 KB)
Can you please analyze these logs & confirm the reason for the failure to transmit/transfer the data?
Have you ever performed a data interaction? Like QPING
