YFGA233E3AM antenna and lc29hda
I would like to use antenna mentioned on topic and RTK module. RTK module manufactured from waveshare. this is the link of RTK module https://www.waveshare.com/lc29h-gps-hat.htm?sku=25279.
The module comes with 28dbi gain antenna, but this has 3m cable and cable converter. And this is external antenna. I would like to use quectel antenna instead of coming from package. Is quectel antenna works with this rasberry hat?
Hi @Tayfun_CELIK ,
From the RTK module LC29HDA as in the link, the package antenna comes together is GNSS active antenna.
If you prefer to use Quctel Antenna (Model: YFGA233E3AM), Link (https://www.quectel.com/product/yfga233e3am-gnss-passive-l1-l5-screw-mount-antenna/#summary), you may use it as this antenna where it also a multi-band active GNSS antenna.
You may contact our local salesperson for purchasing: mert.tastan@quectel.com
Best regards,
