Here are the 3 FW versions for the devices I have:
EC25EUGAR06A09M4G_01.200.01.200
BG95M3LAR02A03_01.200.01.200
BG96MAR02A07M1G_01.200.01.200
Thank you
Regards
Thank you
Regards
I have sent the latest firmware to you, please check, and I hope you can click the
for me
With QFlash_V7.3, for the 3 FW you send me, I have the following error:
No Key(json.blf) file is found, this zip file maybe a invalid zip or you downloadmode is not right , please check it
Cannot find any downloadmode option… What should I do?
Could you confirm that I have to use QFlash v 7.3 to update the FW?
Why does the FW you send me do not contain .bin and .blf (like the UC200 FW I already have)?
Hello @herbert.pan-Q ,
As I said, the FW you send me are not accepted by QFlash 7.3. THere is no blf file in the zip, and it seems mandatory to have it present.
Could you please send me informations on how to use the FW (or other FW file) to update my devices with last FW version.
Thank you
You seem to have activity on the forum but you do not answer me. As you requested, I send you my current FW version. But the new FW you send me are not accepted by QFlash 7.3 (no json.blf)
Could you please provide me FW that are accepted by QFlash are the correct methode to use the FW you provide to update the devices.
Hi @Antoine.Nauzet
In generally speaking, these three FW version are all accepted by all version QFlash so I will send you the QFlash User Guide and you can check the specific upgrade process again.
(post deleted by author)
hi my device is still on EC25ECGAR06A08M1G_01.001.01.001 firmware version. where can I download the latest version?
Hi Quectel team, for the Quectel EC200A, is there a newer firmware than EC200AEUHAR01A19M16?
We have a problem where the LTE interface will not forward inbound routed traffic, which I am told is a know issue. (Its described in more detail here No routes networks on RB912-LTE (2004) with EC200A modem - #4 by nzlme - General - MikroTik community forum).
If there is a newer firmware than EC200AEUHAR01A19M16 which fixes the routed traffic over LTE issue please let me know.
Thanks, nzl.
for me
for me
Hi! Can you send me last firmware for my modules:
I have a lot modules with firmware:
EC25EFAR06A03M4G
and
EC25EUGAR06A05M4G
My e-mail : virus1atl@gmail.com
Thanks alot!
for me
Thanks!
Can i use these firmware(EC25ECGAR06A16M1G_20.200.20.200) for EC25EU?
it is the latest firmware version
thanks a lot @herbert.pan-Q
Can you also send me the latest firmware for the following device,please?
EC21EUGAR06A01M4G_OCPU_01.001.00.000
For the version of OpenCPU, you need to obtain it through your purchasing channel
Hi herbert,
Could you send me the latest firmware and driver for EC25-J to be used over USB from both Linux and Windows?
I’m currently on old firmware and was told new firmware fixes the problem.
Current firmware:
AT+CVERSION
VERSION: EC25JFAR06A05M4G
Nov 6 2019 09:28:33
Authors: QCT
Thanks in advance!
for me
Hello
Could I please get the latest version to BG95-M3, have a very old modem and want to do some tests.
20:57:51.572> AT+GMM
20:57:51.572>
20:57:51.572> BG95M3
20:57:51.572>
20:57:51.572> OK
20:57:53.816> AT+GMI
20:57:53.816>
20:57:53.816> Quectel
20:57:53.816>
20:57:53.816> OK
20:57:56.754> AT+GMR
20:57:56.754>
20:57:56.754> BG95M3LAR02A02
20:57:56.754>
20:57:56.754> OK
Thank You
