Where can I download firmware from?
@herbert.pan-Q can you send me for EM05, but linux version and specificallyEM05GFAR07A07M1G ? Currently I have EM05EFAR06A04M4G and it causes for me some issues which were probably solved within EM05GFAR07A07M1G.
Could you send me the latest update for an EG25-G: EG25GGBR07A08M2G?
sorry herber i don’t find the file? can you send me another time?
please
Thank you. I got the firmware and updated the quecetel module. The module version is EC25-EC. The problem is that the gps is not fixed. I checked nmea port and tried related at commands but no gps incomings. I have another module EC25-EU and this module’s gps works in the same location as ec25-ec. It has the following firmware version:
EC25EUGAR06A07M4G
Can you send me a different firmware for EC25-EC which gps also works correctly?
Thank you indeed
Could you send me the following firmware for EC25-EU?
EC25EUGAR06A07M4G
Email: emadkebriaei@gmail.com
thank you!
hi herbert i didn’t find the firmware EG06ELAR04A20M4G in the email. Can you sent me another time? please i need the procedure to upgrade it when the modem has the problems with the rutx11 that don’t see him.
Can you provide another valid email address?
I have sent the latest firmware to you, please check, and I hope you can click the :yellow_heart: for me
Thank you for sharing the firmware (EC25ECGAR06A14M1G). AT+QOPS command work in this version but unfortunately GNSS can not lock in this version. Do you have any newest version which supports both and works also? I would be thankful if you can send such version to my Email address.
Hi herbert,
Could you send me a firmware and tools to upgrade over USB from Linux for EC21-J?
I’m currently on old firmware and was told new firmware fixes the problem.
Current firmware:
AT+CVERSION
VERSION: EC21JFAR02A05M4G
May 26 2017 10:52:09
Authors: QCT
Please send me 2 versions - EC21JFAR06A05M4G and the latest one. Thanks in advance!
Hi, I’m seeking latest firmware for EG21-G (mini-PCIe) and and EG25-G (mini-PCIe)
I’m currently running EG21GGBR07A11M1G_30.201.30.201
Unsure what my EG25 is, I don’t have it installed right now
Regards
May I have latest RG520N-EB firmware as well?
I am using the BC660-GK module and found out that I need to flash the firmware first in order to make it work. Earlier I bought BC660K-GL-TE-B KIT and it was already having the AT firmware. Also, I want to flash it via another devcie not from the quectel flashing tool. Could you please share me the guide so that I can write my own script for flashing it?
Email ID: ashish.armofthings@gmail.com
Can I please get the latest firmware for EG91-EX (EG91NSGAR05A03M4G)
thank you!
my email: proelektroasup@gmail.com
I have sent the tool to your email,pls check,and I hope you can click the :yellow_heart: for me
I have sent the latest firmware to your email,pls check,and I hope you can click the :yellow_heart: for me
pls provide your detail version
AT+QGMR
it is the latest firmware
I have sent them to your email,pls check,and I hope you can click :yellow_heart: for me,thx
