Using the EC200U hardware Solution in other continent
Victor, Thank you for your help and clarifications till date on the queries. I appreciate your quick responses.
Please provide your comment on the following process. Considering previous logs for reference.
  1. Operate ID set to 0
  2. SIM 0 & SIM 1 network registered Success – Does this success response is for SIM0 / SIM0 & SIM1
  3. We Initiate the Data call on SIM0
  4. checking nw_signal strength for SIM0 → data received with success response
Actual query
  1. Hold the Data related task of application
  2. Set operate_id as 1
  3. Will the data_call established by SIM0 will be active / terminated at this stage?
  4. Incase, not terminated can we check nw_signal strength of the SIM1 with parameter nSim=0 without affecting the network connection of the SIM0 (operate_id 0).
  5. Switch back to operate_id =0 and data transmission of the data through SIM0.
  6. Repeat step 1 to 5 at regular interval say every 5 mins / 10 mins.
Hi @Inventor_TM
After setting the operate ID to 0, the network registration should be SIM 0.
And if you set operated ID to 1, previous data call should be terminated. However we recommend stopping the datacall manually.
Your idea of selecting different SIM based on the network signal strength is unfortunately not well supported on DSSS solution. But you could have some workaround (like changing operate id) with a short internet outage time.
