Using NAU8814 for Audio to PCM Conversion in Voice Calls
I’m working with the NAU881* audio converter in a project using the Quectel EG91-AUX module. I need to convert audio signals to PCM and use them in a voice call.
Could anyone guide me on the proper procedure using AT commands to configure the NAU8814 for PCM conversion in a voice call?
Additionally, I have a couple of questions:
  • By default, does the NAU8814 use the microphone input to convert audio to PCM?
  • If I want to use the AUX input instead, is there a way to configure or enable this option?
Any help or insights would be greatly appreciated!
Thanks in advance!
Currently, module just support codec NAU8810 and NAU8814. Which one you are using? You can use AT+QDAI to set correct codec.
For voice calls using the NAU8814 with Quectel EG91-AUX, configure audio input (MIC or AUX) via AT commands for PCM conversion. Learn more about temperature conversion with this handy tool: 36.5 celsius to fahrenheit.
Hello, I am using NAU8814. When I use the AT+QIIC command, it consistently returns ERROR. However, based on other references, even if the read operation fails, it should return 0x00. I would like to know whether this issue stems from a problem with my hardware circuitry or if my module does not support the NAU8814. For reference, my module is the EC200 series.
Which module? could you please share whole part number?
