Upgrade Frimware on RMU500-EV
Hello!
I want to upgrade the firmware of the Quectel RM520N-GL which is placed on the RMU500-EV. The module is placed with a layer of silicon on Evaluation Board which makes it not so easy to force the download mode via pin bridging.
I tried the FOTA method but it wont work - same with the at+boot=1 commando to set the module in Download mode.
Any tipps on how to upgrade it?
Thank you in advance!
Dear @Sebkl
Do you try to contact the EVB to PC and use Qflash to upgrade?
Yes I did and QFlash wont recognize the Firmwares .zip file. The Internet suggested, that the modem is not in the correct download mode.
Dear @Sebkl
Please check user guide, you need to unzip the file and select corresponding file.
