I want the lastest Firmare of EG915
and I want to support gpsOneXTRA one firmware
Please provide your detailed firmware version
AT+QGMR
ATI
EG915N
Revision: EG915NEUAPR03A03M16
I have sent them to you,pls check,and I hope you can click the
for me,thanks
I am experiencing a problem with uploading the firmware you sent.
I can only upload a ZIP file, but I encounter a timeout error each time I attempt to upload it:
Here’s the development kit I’m using:
However, I am using the EG915 module. I am unsure which port to use for the firmware update:
- Should I use the COM port (UART)?
- Or should I use the USB port? If so, which one?
Here’s a photo of the available ports:
Any guidance would be greatly appreciated.
You can pull the BOOT pin up by forcing download mode
thanks it’s work with me ![]()
Please provide your full firmware version
AT+QGMR
