Unable to set n257 as preferred band on RG530F-EU module
Hi, I have a RG530F-EU module in 5GDM01EK evaluation kit. I received the latest firmware from our supplier, which was supposed to solve other issues.
We try to connect the module to 5G SA in n257, so I try to set the band as preferred one with:
AT+QNWPREFCFG=nr5g_band,78:257
It returns:
+CME ERROR: 735
Any hints are really appreciated.
Regards,
Dear @duhovnikov
AT+QNWPREFCFG=“nr5g_band”,78:257
or
AT+QNWPREFCFG=“nr5g_band”,257
Dear @silvia
The issue has been resolved through another support channel with FR2 SA application note.
Thanks.
Hi, @duhovnikov
We have exactly the same problem. Could you please let us know how did you solve it? I cannot find the solution in any forum.
(post deleted by author)
Dear @Pablo_Herrera_Diaz @duhovnikov
Please share the infoemation about how to fix this.
Thanks.
There is an application note FR2_SA_Application_Note, that you @ quectel should have it. Unfortunately, I cannot share it as the document is labeled as confidential.
