Using the RK3588 Android 14 SDK and integrating Quectel_Android_RIL_Driver_V4.0.10-0805, I tested with a China Unicom 4G SIM card. The data network works fine, and receiving SMS is also normal, but sending SMS fails. However, when using Quectel_Android_RIL_Driver_V3.5.66, sending SMS works correctly.
When comparing the two versions of the RIL while sending the same SMS message “test hidl +1,” the RIL logs show the following differences:
Successful Case:
11-21 14:41:36.402 682 682 D ATC : AT> AT+CMGS=24
11-21 14:41:36.404 682 1067 D ATC : AT< >
11-21 14:41:36.404 682 1067 D ATC : AT> 0891683110200005F001000B813109220960F300000CF4F29C0E42A7C96CD02A06^Z
11-21 14:41:36.734 682 1067 D ATC : AT< +CMGS: 94
11-21 14:41:36.734 682 1067 D ATC : AT< OK
Failed Case:
11-21 23:28:26.877 681 681 D ATC : AT> AT+CMGS=24
11-21 23:28:26.880 681 1178 D ATC : AT< >
11-21 23:28:26.880 681 1178 D ATC : AT> 1D81000230083006300130033000300130003002300030003005300030F001000B813109220960F300000CF4F29C0E42A7C96CD02A06^Z
11-21 23:28:26.883 681 1178 D ATC : AT< +CMS ERROR: 304
11-21 23:28:26.883 681 681 E SMS : ql_sendSMS error
Could you please assist in resolving the SMS sending issue? Thank you!
Update:
After further investigation of the logs, I discovered a potential issue with the SMSC address handling during SMS sending. Here are the relevant logs for comparison:
Successful case:
11-21 14:41:36.388 682 682 D RILC : onRequest: GET_SMSC_ADDRESS
11-21 14:41:36.388 682 682 D RILC : onRequest,7662 g_is_scan_ing = 0
11-21 14:41:36.388 682 682 D ATC : AT> AT+CSCA?
11-21 14:41:36.391 682 1067 D ATC : AT< +CSCA: "002B0038003600310033003000310030003200300030003500300030",145
11-21 14:41:36.391 682 1067 D ATC : AT< OK
11-21 14:41:36.391 682 682 D RILC : RequestComplete, RIL_SOCKET_1
11-21 14:41:36.391 682 682 E RILC : Calling responseFunction() for token 122
11-21 14:41:36.391 682 682 D RIL_SERVICE_1_1: getSmscAddressResponse: serial 122
11-21 14:41:36.392 1068 2097 D RILJ : [0122]< GET_SMSC_ADDRESS +8613010200500 [PHONE0]
Failed case:
11-21 23:28:26.857 1091 2326 D RILJ : [0160]> GET_SMSC_ADDRESS [PHONE0]
11-21 23:28:26.857 681 681 D RadioMessaging: getSmscAddress(): 160
11-21 23:28:26.857 681 681 D RILC : onRequest: GET_SMSC_ADDRESS
11-21 23:28:26.857 681 681 D ATC : AT> AT+CSCA?
11-21 23:28:26.862 681 1178 D ATC : AT< +CSCA: "002B0038003600310033003000310030003200300030003500300030",145
11-21 23:28:26.862 681 1178 D ATC : AT< OK
11-21 23:28:26.862 681 681 D RadioMessaging: getSmscAddressResponse: serial:160, slotId:0
11-21 23:28:26.863 1091 1127 D RILJ : [0160]< GET_SMSC_ADDRESS 002B0038003600310033003000310030003200300030003500300030 [PHONE0]
Upon comparison:
The AT command AT+CSCA? returned the same raw result in both cases.
However, in the successful case, the decoded SMSC address is +8613010200500, as expected.
In the failed case, the SMSC address remains in its raw encoded format (002B00380036...) and is not properly decoded, leading to an incorrect SMSC address in the final PDU.
I have found the problem.
It is because the AIDL version it sent the AT+CNMI=1,2,2,1,0
If I try
echo -ne “at+cnmi=2,2\r” > /dev/ttyUSB2
And then the SMS sending works.
Maybe you can try add the AT comand AT+CNMI=2,2 in the ql-ril.conf.
