Hi all, I’m using L26-LB module whit GPS+GLONASS. Is possible to have as Talker ID “GP” (NOT “GN”)?
Hi @Sbilf
There is no command to change the Talker ID from “GN” to “GP”.
It is recommended that you update this part of the logic in the host code when reading NMEA yourself. Because starting from NMEA version 4.10, it has been clearly stated that the Talker ID of the combined system is “GN” instead of “GP”.
If you must use GP, you can only identify “GN” from the host and change it to “GP” yourself.
