Hi i send again,please check.
EG25GGBR07A08M2G_30.200.30.200, AT+QURCCFG? read command no longer work - reply is ERROR.
Can write and test command, can’t read value.
Read Command
AT+QURCCFG?
Response
Return current configurations:
+QURCCFG: “urcport”,
Can you reboot the device and try again? It was normal before the upgrade, right?
I did reboot. Yes, it was ok before upgrade. I have 2 similar devices, all behave the same. Upgrade was successful no errors. Works ok, just this command (read status only) is no longer work as expected.
You can use AT+QURCCFG=“urcport” this command to check.
Hello, I have the firmware EG25GGBR07A08M2G_30.006.30.006 and I would like the latest version if possible. The email is: ady_gligor@yahoo.com.
Thank you.
Hi @blondu
I have sent the latest firmware to you. Please note that the old version cannot be restored after upgrading the latest firmware.
I downloaded it, thank you.
