SSL handshake issue
I am having issue in sending data to my server hosted on render following is my code
#include <HardwareSerial.h>
#define EC200U_RX 12
#define EC200U_TX 13
HardwareSerial ecSerial(2); // UART2
void sendCommand(String cmd, int wait = 2000) {
  ecSerial.println(cmd);
  delay(wait);
  while (ecSerial.available()) {
    Serial.write(ecSerial.read());
void setup() {
  Serial.begin(115200);
  ecSerial.begin(115200, SERIAL_8N1, EC200U_RX, EC200U_TX);
  delay(5000); // Wait for EC200U to boot
  Serial.println("Initializing EC200U...");
  // 1. Set APN
  sendCommand("AT+QICSGP=1,1,\"airtelgprs.com\",\"\",\"\",1"); // Use your APN
  sendCommand("AT+QIACT=1");
  sendCommand("AT+QIACT?");
  // 2. Enable SSL
  sendCommand("AT+QSSLCFG=\"sslversion\",1,4");
  sendCommand("AT+QSSLCFG=\"ciphersuite\",1,0XFFFF");
  sendCommand("AT+QSSLCFG=\"seclevel\",1,0");
  // 3. Setup HTTPS context
  sendCommand("AT+QHTTPCFG=\"contextid\",1");
  sendCommand("AT+QHTTPCFG=\"sslctxid\",1");
  // 4. Set URL to your Render endpoint
  sendCommand("AT+QHTTPURL=49", 100);
  sendCommand("https://iot-x0kv.onrender.com/api/fuel-data/heptan", 4000); // Adjust length accordingly
  // 5. Send POST request
  String json = "{\"latitude\":30.7421,\"fuel\":85,\"longitude\":76.7781}";
  int payloadLength = json.length();
  sendCommand("AT+QHTTPPOST=" + String(payloadLength) + ",60,60", 100);
  sendCommand(json, 3000);
  // 6. Read response
  sendCommand("AT+QHTTPREAD=60", 3000);
void loop() {
  // nothing here
when i am trying to send https on thingsboard it’s working but when i try to do with my server it’s failing and giving +CME ERROR 732.
i checked cipher suites supports of device and it support one of my cipher suite. on tls1.2
as i am runing server on render it don’t require any certificate also.
what could be the problem ?
POST /api/fuel-data/heptan HTTP/1.1
Host: iot-x0kv.onrender.com
User-Agent: Apifox/1.0.0 (https://apifox.com)
Content-Type: text/plain
Accept: /
Connection: keep-alive
{“latitude”:30.7421,“fuel”:85,“longitude”:76.7781}
Can your URL be accessed?
yes it is a post route
I validate with POSTMAN, returning 400
please try
POST /api/fuel-data/trial HTTP/1.1
and send the code please if worked
