I request guidance on setting up the EC200A-EU module on my Debian OS. Could you please provide me with the necessary drivers and any instructions or documentation required for the setup?
Did you search the forum?
Show the output of cat /sys/kernel/debug/usb/devices
No pictures please.
T: Bus=01 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2c7c ProdID=6005 Rev= 3.18
S: Manufacturer=Android
S: Product=Android
S: SerialNumber=0000
C:* #Ifs= 5 Cfg#= 1 Atr=e0 MxPwr=500mA
A: FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=03
I:* If#= 0 Alt= 0 #EPs= 1 Cls=e0(wlcon) Sub=01 Prot=03 Driver=rndis_host
E: Ad=87(I) Atr=03(Int.) MxPS= 64 Ivl=4096ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=rndis_host
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0c(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0b(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0f(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=89(I) Atr=03(Int.) MxPS= 64 Ivl=4096ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0a(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=88(I) Atr=03(Int.) MxPS= 64 Ivl=4096ms
Assuming your Linux kernel is not outdated, this modem should be supported by the standard drivers - option
, cdc_ether
With serial driver loaded switch the modem from RNDIS to ECM (AT+QCFG="usbnet"
), then configure “dialing” with +QNETDEVCTL
, you can find examples in the forum.
ls /dev/ttyUSB is not working, what is your suggestion? how to up the EC200A-EU module?
Assuming the standard drivers are installed, run sudo modprobe option
then re-read with cat /sys/kernel/debug/usb/devices
