SC20EL Kernel configuration using Menuconfig
I am using docker image in ubuntu for firmware compilation.
I am new with Yocto and I want to add/remove some drivers in Kernel image by Menuconfig. But I didn’t find any guidelines for this.
It will be appreciated if you inform me.
Please add it in the following directory:
kernel/msm-3.18/arch/arm/configs/msm8909_defconfig
Thank you for your reply.
Could you please let me know the steps:
In which directory should I run command?
Which command shoul I use? Rebake or bitbake?
Could you please write the exact command?
You can add or delete kernel configuration in the directory file I provided
Compile command:
rebake virtual/kernel
