SC20 - Signing Android Release
Dear all,
I’m trying to sign an Android Release (Version 7.1.2) with my release keys, but it is not working.
See error below:
signing: MobileUpdateClient.apk         (/home/estanislau/work/projects/wellpay/repos/x1_certs/release/platform)
ERROR: No minSdkVersion returned by aapt
More verbose:
running:  aapt dump badging /tmp/tmpnEoKHL
Does anybody have an idea? I’m following the steps described on Android Source page (https://source.android.com/devices/tech/ota/sign_builds), my keys don’t have password at this moment, because trying with password I have another error from Java.
Thanks in advance
Can you tell me which command you are using to sign.
Hello Jax.
See the commands execute from build until sign:
Build:
$ source build/envsetup.sh
$ lunch msm8909-userdebug
$ make -j16 dist DIST_DIR=~/dist_output/
Generate keys:
$ subject='/C=BR/ST=Sao Paulo/L=Sao Paulo/O=My Company/OU=R&D/CN=MyCompany/emailAddress=contato@mycompany.com.br'
$ for x in releasekey platform shared media; do ./development/tools/make_key ~/release/$x "$subject" ; done
Signing:
$ ./build/tools/releasetools/sign_target_files_apks -v --default_key_mappings ~/release ~/dist_output/msm8909-target_files.zip ~/dist_output/signed-msm8909-target_files.zip
Output eror when keys are generated without password
ERROR: No minSdkVersion returned by aapt</i>
When I generate keys protecting them with a password, I have another error, see below:
running: openssl pkcs8 -in /home/ubuntu/release/media.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/media.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in /home/ubuntu/release/platform.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/platform.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in /home/ubuntu/release/releasekey.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/releasekey.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in /home/ubuntu/release/shared.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in /home/ubuntu/release/shared.pk8 -inform DER -passin pass:
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/cts-testkey1.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/cts-testkey2.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-a.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-b.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-c.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in cts/hostsidetests/appsecurity/certs/keysets/cts-keyset-test-ec-a.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/keyset/…/…/certs/keyset_A.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/keyset/…/…/certs/keyset_B.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/version/…/…/certs/unit_test.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/version/…/…/certs/unit_test_diff.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in frameworks/base/core/tests/coretests/apks/version_nosys/…/…/certs/unit_test.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in vendor/unbundled_google/libraries/certs/clockwork.pk8 -inform DER -nocrypt
running: openssl pkcs8 -in vendor/unbundled_google/libraries/certs/clockwork.pk8 -inform DER -passin pass:
Enter password for /home/ubuntu/release/media key>
Enter password for /home/ubuntu/release/platform key>
Enter password for /home/ubuntu/release/releasekey key>
Enter password for /home/ubuntu/release/shared key>
rewriting RECOVERY/RAMDISK/default.prop:
replace: ro.bootimage.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/test-keys
with: ro.bootimage.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/release-keys
replace: ro.build.display.id=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300 test-keys
with: ro.build.display.id=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300
replace: ro.build.tags=test-keys
with: ro.build.tags=release-keys
replace: ro.build.description=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300 test-keys
with: ro.build.description=msm8909-userdebug 7.1.2 N2G47H eng.ubuntu.20200113.210300 release-keys
replace: ro.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/test-keys
with: ro.build.fingerprint=qcom/msm8909/msm8909:7.1.2/N2G47H/ubuntu01132103:userdebug/release-keys
rewriting BOOT/RAMDISK/default.prop:
signing: Telecom.apk (/home/ubuntu/release/platform)
running: aapt dump badging /tmp/tmprvx6Wk
running: java -Xmx2048m -Djava.library.path=out/host/linux-x86/lib64 -jar out/host/linux-x86/framework/signapk.jar --min-sdk-version 25 /home/ubuntu/release/platform.x509.pem /home/ubuntu/release/platform.pk8 /tmp/tmprvx6Wk /tmp/tmpIEEA9j
java.lang.ClassCastException: org.bouncycastle.asn1.DLSequence cannot be cast to org.bouncycastle.asn1.ASN1Integer
at org.bouncycastle.asn1.pkcs.PrivateKeyInfo.(PrivateKeyInfo.java:79)
at org.bouncycastle.asn1.pkcs.PrivateKeyInfo.getInstance(PrivateKeyInfo.java:45)
at com.android.signapk.SignApk.readPrivateKey(SignApk.java:271)
at com.android.signapk.SignApk.main(SignApk.java:1105)
ERROR: signapk.jar failed: return code 1
Dear all,
Issue solved.
  1. MobileUpdateClient is a package pre-compiled on MSM8909 build environment and doesn’t have the minSdkVersion defined on its AndroidManifest.xml (checked with Android Studio). Just removed it from final image.
  2. Package RootPA’s AndroidManifest makes reference to versionCode on APK resource’s XML. I changed it keeping the versionCode on AndroidManifest with same value.
Kind Regards,
Alexandre
