First check that the base has a good submetric fix, (if you followed the survey); otherwise if you don’t have the accurate coordinates you can use the PPP_Galileo_HAS with the PPP firmware.
on that forum U can read all of 290p…quectel doc included.
Set the base with the fix satus
$PQTMGNSSSTOP*09
Set the base in ecef $PQTMCFGSVIN,W,2,0,0,x,y,z*<Checksum>
$PQTMCFGSVIN,R*26 check if ecef base is correct
$PQTMSAVEPAR*5A
$PQTMSRR*4B
set rtcm msm7 and ephemerides output at 5°
$PQTMCFGRTCM,W,7,0,5,07,06,2,1*35
$PQTMCFGMSGRATE,W,RTCM3-1033,0*5D
$PQTMCFGMSGRATE,W,RTCM3-1005,1*59
$PQTMSAVEPAR*5A
$PQTMSRR*4B
ensure all msm7 are outputted
$PQTMCFGMSGRATE,W,RTCM3-107X,1,0*2F
$PQTMCFGMSGRATE,W,RTCM3-108X,1,0*20
$PQTMCFGMSGRATE,W,RTCM3-109X,1,0*21
$PQTMCFGMSGRATE,W,RTCM3-111X,1,0*28
$PQTMCFGMSGRATE,W,RTCM3-112X,1,0*2B
$PQTMCFGMSGRATE,W,RTCM3-113X,1,0*2A
$PQTMSAVEPAR*5A
$PQTMSRR*4B
enable ephemerides output
$PQTMCFGMSGRATE,W,RTCM3-1019,0*55
$PQTMCFGMSGRATE,W,RTCM3-1020,0*5F
$PQTMCFGMSGRATE,W,RTCM3-1041,0*58
$PQTMCFGMSGRATE,W,RTCM3-1042,0*5B
$PQTMCFGMSGRATE,W,RTCM3-1044,0*5D
$PQTMCFGMSGRATE,W,RTCM3-1046,0*5F
$PQTMSAVEPAR*5A
$PQTMSRR*4B
quectel_lg290p03lgx80p03_gnss_protocol_specification_v1-1.pdf (736.3 KB)
