RM551E - Asking for help about VoLTE
Good day everyone!
May I know a reliable method to enable / disable VoLTE on my RM551E running the latest version?
RM551EGL00AAR01A02M8G_01.001.01.001
Also, how can I query the modem to know if my current connection is indeed using or have an active VoLTE? Thanks!
Check with AT command
AT+QCFG="ims"
AT+CGDCONT?
AT+QCFG=“ims”
returns 0,0 parameter
How about CGDCONT? What specific parameter should I check?
It means that it is not enabled.
Try
AT+QCFG="ims",1,1
If not working
AT+QIMSCFG="ims_enable",1
AT+QCFG="ims",1,1 didn’t work so I tried the second command and this is the response after enabling it:
+QIMSCFG: "ims_enable",1,0,0
For CGDCONT:
AT+CGDCONT?
+CGDCONT: 1,"IPV4V6","SMART5G","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,,"",,,,0
+CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0,,,,,,,,,,"",,,,0
+CGDCONT: 3,"IPV4V6","sos","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1,,,,,,,,,,"",,,,0
+QIMSCFG: “ims_enable”,1,0,0
The last 0 means that it is not capable of the VoLTE. The module even do not support voice call by default.
Good day. Is there an available reference for the supported CA Combinations of RM551E-GL? Thanks!
