RM520N-GL latest firmware and drivers for Windows and Linux
can I get a link to the Quectel Linux drivers (USB, PCIe drivers) and the Connection Manager? I have a device that is setup in PCIe mode but got no AT port exposed and cannot communicate with it.
Thanks!
@stex
You may try via ATI command. Additionally, do you have any tool to execute AT command? Much appreciation
no, that is my problem. ModemManager says no AT port available, and I do not have any other tool to run AT commands on linux
Dear @wundercat
I have sent USB and PCIe driver to you via Message, please check.
Please note you only can install one driver.
May you please send me the latest firmware vesion as well?
I want to integrate the Module with imx.8 from NXP. Pcie interface is used to connect the module with the board. Yocto-based Linux is used. would you please send me the corresponding pachkage?
Hi @Dali_Fahmy
Could you please help check corresponding firmware version in your side? Much appreciation.
I got the drivers from you however, once installed these still appear under device manager
I did a complete fresh windows install, I simply want the unit to work with windows, card is installed via m.2 Key on the motherboard. just require the drivers or software to make it work. can anyone give me some direction?
You’ll need the PCIe drivers. Looks like the module is being utilized over PCIe as an endpoint based on those device descriptors.
@silvia may have the latest Windows PCIe drivers. I have a version of them but it started blue screening on windows 11 at one point.
May also give the Lenovo RM520N-GL driver a try as it’s used over PCIe as well. Google should have that one.
(post deleted by author)
Apologies for the super newb question, but if I want to use this as a modem for LTE-A or 5G, do I need to upgrade my firmware? I’m using Windows 11 (if that matters) and a “Waveshare 5g m.2 to gigabit ethernet converter”.
AT
AT+CVERSION
VERSION: RM520NGLAAR03A03M4G Mar 1 2024 06:38:05 Authors: Quectel
AT+CSUB
SubEdition: V04
AT+QGMR
RM520NGLAAR03A03M4G_01.201.01.201
Thanks!
Dear @iamromulan @Amed
If install in PC directly, it need PC manufacture to provide driver.
could i get the latest firmware as well?
Thanks!
Hi,@Jeratt
I have sent it to you via email,pls check
Hi;
Can i get the latest firmware as well?
I have RM520NGLAAR01A07M4G for now
Thanks!
Dear @Grimwork
Thank you Leon! Appreciate you!
Can you please share the RM520N-GL for windows 11 22H2 (OS Build: 22621.3737) ..?
Hi @dhaneshr
what is your current firmware version? Much appreciation
Hi @Jonathan.wang , i am trying to connect the RM520N-GL modem via USB dongle to my Laptop which is now updated to latest windows 11 24H2 version. when i am trying to connect the modem in device manger it shows as it needed the drivers. so i am expecting a windows driver for this modem.
Windows 11 24H2 (OS Build : 26100.4061)
