Hi , i have been struggling with my 5G modem. I am using OAIBOX as an network. When i connect my UE , it sometime get the IP for data, but most of the time i am struggling as the UE doesnot get the IP. I need the fix.
Here are the logs:
[10-23_18:12:43:128] QConnectManager_Linux_V1.6.5.1
[10-23_18:12:43:128] Find /sys/bus/usb/devices/2-2 idVendor=0x2c7c idProduct=0x801, bus=0x002, dev=0x004
[10-23_18:12:43:128] Auto find qmichannel = /dev/cdc-wdm1
[10-23_18:12:43:128] Auto find usbnet_adapter = wwan0
[10-23_18:12:43:128] netcard driver = qmi_wwan, driver version = 6.8.0-85-generic
[10-23_18:12:43:128] Modem works in QMI mode
[10-23_18:12:43:137] cdc_wdm_fd = 7
[10-23_18:12:43:230] Get clientWDS = 15
[10-23_18:12:43:262] Get clientDMS = 1
[10-23_18:12:43:294] Get clientNAS = 3
[10-23_18:12:43:326] Get clientUIM = 2
[10-23_18:12:43:358] Get clientWDA = 1
[10-23_18:12:43:390] requestBaseBandVersion RM520NGLAAR03A04M4G
[10-23_18:12:43:518] requestGetSIMStatus SIMStatus: SIM_READY
[10-23_18:12:43:582] requestGetProfile[pdp:1 index:1] oai///0/IPV4
[10-23_18:12:43:582] requestSetProfile[pdp:1 index:1] oai///0/IPV4
[10-23_18:12:43:582] no need to set skip the rest
[10-23_18:12:43:614] requestRegistrationState2 MCC: 1, MNC: 1, PS: Attached, DataCap: 5G_SA
[10-23_18:12:43:646] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[10-23_18:12:43:646] ip addr flush dev wwan0
[10-23_18:12:43:649] ip link set dev wwan0 down
[10-23_18:14:03:677] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[10-23_18:14:03:677] call_end_reason is 1
[10-23_18:14:03:677] call_end_reason_type is 3
[10-23_18:14:03:677] call_end_reason_verbose is 1140
[10-23_18:14:03:677] try to requestSetupDataCall 5 second later
[10-23_18:14:08:701] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[10-23_18:14:08:701] call_end_reason is 1
[10-23_18:14:08:701] call_end_reason_type is 2
[10-23_18:14:08:701] call_end_reason_verbose is 209
[10-23_18:14:08:701] try to requestSetupDataCall 10 second later
[10-23_18:14:18:716] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[10-23_18:14:18:716] call_end_reason is 1
[10-23_18:14:18:716] call_end_reason_type is 2
[10-23_18:14:18:716] call_end_reason_verbose is 209
[10-23_18:14:18:716] try to requestSetupDataCall 20 second later
[10-23_18:14:38:747] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[10-23_18:14:38:748] call_end_reason is 1
[10-23_18:14:38:748] call_end_reason_type is 2
[10-23_18:14:38:748] call_end_reason_verbose is 209
[10-23_18:14:38:748] try to requestSetupDataCall 40 second later
