RM520N-GL - FTM Application Note needed
in a project I’m using a RM520N-GL (FW: RM520NGLAAR01A08M4G)
For radio performance testing I need a FTM Applicaation Note for that module.
Can you please send me the document?
Hi Sir
i will check and reply when i get the document. Much appreciation
We have the same problem. Could you kindly provide us the same information?
Hi,@eruffaldi
I’ve already sent you the relevant documents via email. You can find the AT commands related to the FTM function in them.I hope it can be helpful to you.
I also need access to the FTM Application Note for my RM520N-GL Quectel Module.
Please, could you resend me some relevant document?
Dear @gfeijoo
Thank you for the document @silvia. I have another request, in the last application notes from Quectel RM520N-GL I could found some information about AT commands at+qtxftmex and at+qtxftmsrs.
I tested o my side, and see that module supports it, with parameters:
at+qtxftmex=?
+QTXFTMEX:,<tx_enable>,,<tx_power_dbm10>,<pwr_class>,,,<tx_index>,<tx_waveform>,<tx_modulation>,<rb_start>,<rb_count>,<nr_scs>
at+qtxftmsrs=?
+QTXFTMSRS: <tx_enable>,,<tx_power_dbm10>,,<tx_index>
Could you please provide me some document or info available related to the meaning of this parameters and use of this commands, please?
Thanks in advance :slight_smile:
Dear @gfeijoo
Only have AT+QTXFTMEX, I have sent to you via Message, please check.
