Hello, I am porting Android 15/16 to a Qcom sm8350 devices that uses a Quectel RM510Q-GL modem. I am encountering this error when utilizing the stock blobs along with the source built aosp vendor/bin/rild since the device launched on Android 12 and was never updated to 13, using the prebuilt rild results in the following:
11-22 11:11:36.999 4215 4215 F linker : CANNOT LINK EXECUTABLE "/vendor/bin/hw/rild": cannot locate symbol "initWithMmapSize" referenced by "/vendor/bin/hw/rild"...
Using the source built rild, I get the following error:
11-22 16:30:38.606 4520 4520 I HidlServiceManagement: Registered vendor.qti.hardware.radio.qtiradio@2.6::IQtiRadio/slot1
11-22 16:30:38.606 4520 4520 F libc : FORTIFY: memcpy: prevented 858650992-byte write into 32-byte buffer
11-22 16:30:38.606 4520 4520 F libc : Fatal signal 6 (SIGABRT), code -1 (SI_QUEUE) in tid 4520 (rild), pid 4520 (rild)
11-22 16:30:38.628 4525 4525 I crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstoneProto
11-22 16:30:38.629 767 767 I tombstoned: received crash request for pid 4520
11-22 16:30:38.630 4525 4525 I crash_dump64: performing dump of process 4520 (target tid = 4520)
11-22 16:30:38.632 4525 4525 E DEBUG : failed to read process info: failed to open /proc/4520: No such file or directory
11-22 16:30:38.652 702 702 I logd : logdr: UID=1001 GID=1001 PID=4525 n tail=500 logMask=8 pid=4520 start=0ns deadline=0ns
11-22 16:30:38.668 702 702 I logd : logdr: UID=1001 GID=1001 PID=4525 n tail=500 logMask=1 pid=4520 start=0ns deadline=0ns
11-22 16:30:38.695 4525 4525 F DEBUG : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
BUILD PROP LINE REDACTED
11-22 16:30:38.695 4525 4525 F DEBUG : Revision: '0'
11-22 16:30:38.695 4525 4525 F DEBUG : ABI: 'arm64'
11-22 16:30:38.695 4525 4525 F DEBUG : Timestamp: 2025-11-22 16:30:38.631830977-1100
11-22 16:30:38.695 4525 4525 F DEBUG : Process uptime: 0s
11-22 16:30:38.695 4525 4525 F DEBUG : Cmdline: /vendor/bin/hw/rild -l /vendor/lib64/hw/libquectel-ril.so
11-22 16:30:38.695 4525 4525 F DEBUG : pid: 4520, tid: 4520, name: rild >>> /vendor/bin/hw/rild <<<
11-22 16:30:38.695 4525 4525 F DEBUG : uid: 1001
11-22 16:30:38.695 4525 4525 F DEBUG : signal 6 (SIGABRT), code -1 (SI_QUEUE), fault addr --------
11-22 16:30:38.695 4525 4525 F DEBUG : Abort message: 'FORTIFY: memcpy: prevented 858650992-byte write into 32-byte buffer'
11-22 16:30:38.695 4525 4525 F DEBUG : x0 0000000000000000 x1 00000000000011a8 x2 0000000000000006 x3 0000007fccd20460
11-22 16:30:38.695 4525 4525 F DEBUG : x4 34353734371f6364 x5 34353734371f6364 x6 34353734371f6364 x7 7f7f7f7f7f7f7f7f
11-22 16:30:38.695 4525 4525 F DEBUG : x8 00000000000000f0 x9 fca74375a640167b x10 0000000000000001 x11 0000007bf09062e0
11-22 16:30:38.695 4525 4525 F DEBUG : x12 0000000037780c39 x13 0000000034155555 x14 0000000000000018 x15 00000000377734b8
11-22 16:30:38.695 4525 4525 F DEBUG : x16 0000007bf09720d8 x17 0000007bf0959c40 x18 0000007bf429c000 x19 00000000000011a8
11-22 16:30:38.695 4525 4525 F DEBUG : x20 00000000000011a8 x21 00000000ffffffff x22 0000007fccd20741 x23 0000007fccd20690
11-22 16:30:38.695 4525 4525 F DEBUG : x24 0000007fccd206f0 x25 0000000000000003 x26 0000000000000000 x27 0000000000000000
11-22 16:30:38.695 4525 4525 F DEBUG : x28 0000005c1d11d018 x29 0000007fccd204e0
11-22 16:30:38.695 4525 4525 F DEBUG : lr 0000007bf08f05d8 sp 0000007fccd20460 pc 0000007bf08f05fc pst 0000000000001000
11-22 16:30:38.695 4525 4525 F DEBUG : 8 total frames
11-22 16:30:38.695 4525 4525 F DEBUG : backtrace:
11-22 16:30:38.695 4525 4525 F DEBUG : #00 pc 00000
It seems the vendor implementation used IRadio 1.5 as per the manifest below:
<hal format="hidl">
<name>android.hardware.radio</name>
<transport>hwbinder</transport>
<fqname>@1.2::ISap/slot1</fqname>
<fqname>@1.5::IRadio/slot1</fqname>
</hal>
<hal format="hidl">
<name>android.hardware.radio.config</name>
<fqname>@1.1::IRadioConfig/default</fqname>
</hal>
What could be the issue here, any insight on what to try?
