I have sent it to you,pls check,and I hope you can click the
for me,thx
for me,thx
I have sent R11 to you,not found the R5,pls check,and I hope you can click the
for me,thx
Hello
Pleas could I get the latest firmware and flash tool / process to upgrade on windows system:
RM502QGL
Revision: RM502QGLAAR05A03M4G
Mail to patrick_howell@hotmail.com
Hello, I would like you to send me the latest firmware. Thank you. aleksandar.kosak@gmail.com
Unfortunately, the email did not arrive. I also checked the spam folder. Please send it again. Thank you.
Dear @aleksandar_kosak
Hello Silvia,
In the description, my version of the firmware is shown.
I have two issues:
Issue 1:
I’m wondering if the card supports eSIM because the AT+QESIM command only enables eSIM, but any further command results in an error.
Issue 2:
My SIM card is not connecting to 5G. I tried the commands:
AT+QNWPREFCFG="mode_pref",NR5G
AT+QNWCFG="dis_4mimo_enable",0-1
I’m currently waiting for the ordered antennas, as I suspect the signal might be too weak.
Will the R12 firmware resolve the issue with eSIM commands?
[kosak@MikroTik] > interface/lte/at-chat lte1 input=“AT+CGMM”
output: RM502Q-GL
[kosak@MikroTik] > interface/lte/at-chat lte1 input=“AT+CSUB”
output: SubEdition: V01
[kosak@MikroTik] > interface/lte/at-chat lte1 input=“AT+QGMR”
output: RM502QGLAAR11A02M4G_01.200.01.200
[kosak@MikroTik] > interface/lte/at-chat lte1 input=“AT+QESIM="profile_brief"”
output: ERROR
R05 is an early version, I suggest you upgrade directly to the version I sent you and use the tools I sent you,and I hope you can click the
for me,thx
I am not sure if you had download profile successfully, it need tool. Due to some limitation, I can’t share to you, you can contact with your provider to get.
You can use AT+QESIM=? to confirm which AT commands support.
For R12, I didn’t see it on my side, sorry about this.
Hello, please send me the RM502QAEAAR13A04M4G_01.201.01.201 firmware. Thank you. Email: 610663683@qq.com
Hi Sir,
Could you please tell us your current firmware version? Much appreciation.
Hello, the previous version is RM502QAEAAR13A04M4G_01.200.01.200
Hi Sir,
I think my colleague has replied that, Please check. Thx.
Hello Silvia, please send me the original firmware for RM502QGLAA-M20-CASA, as my modem is stuck in EDL mode, and unfortunately, the existing firmwares I have are giving me errors during flashing. I have tried to contact the supplier, but unfortunately, I have not received any response yet.
By the way, I haven’t received any email from herbert.pan-Q yet.
Please share IMEI to us, I will check the original firmware.
Hello Silvia, please check and send me the original firmware. IMEI: 355878110055191
The original firmware is too old, it is not recommended to upgrade the latest firmware.
I will sent the original firmware to your email.
Good afternoon. I bought a RM502Q-GL module and it is not working. The seller has told me that if I have tried to update the firmware, I have seen that people request in this forum the latest firmware needed for quectel devices. Is any additional information about the device needed? Thanks, best regards.
