Rm502 not booting
Hi guys!
I’m chiara from Italy and sending you some request since my bf can’t fix this product.
this module installed on a zyxel device.
During and update the module stopped working and now it bootloop every time he tries to update it.
It connected.it via UART, flashed with z-loader but still at the same point…device is not recognized by the modem
Attaching some picture to the topic maybe some expert help boyfriend fix it.
Thanks in advance
@silvia can you support me ?
photo_2025-03-12_20-14-24
Dear @Tufozz
Actually, we don’t know how to upgrade the firmware with Zyxel, you can contact with manufacture of Zyxel.
Or you can try to uninstall the module, install in other device and try to upgrade.
@silvia
thanks for the reply…
the problem is that is not a problem with zyxel… I installed openwrt, and the module is not working…
it’s a problem with quectel module… in particular restore the functionality …
what test can i perform thorught UART port?
Dear @Tufozz
Did you see any port in your system? like ttyUSB or others?
thanks @silvia
at the time i found those but i don’t know if they are real / not working or what…
any update?
thanks in advance
Show the output of cat /sys/kernel/debug/usb/devices
No pictures please.
@jfrog
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 2
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 6.06
S: Manufacturer=Linux 6.6.73 xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=1e1c0000.xhci
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 1
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 6.06
root@OpenWrt:~# ^C
You have no Quectel devices on USB.
root@OpenWrt:~# ls -l /dev/ttyUSB*
ls: /dev/ttyUSB*: No such file or directory
root@OpenWrt:~# ls -l /dev/ttyusb*
ls: /dev/ttyusb*: No such file or directory
root@OpenWrt:~# ls /dev/tty*
/dev/tty /dev/ttyS10 /dev/ttyS13 /dev/ttyS2 /dev/ttyS5 /dev/ttyS8
/dev/ttyS0 /dev/ttyS11 /dev/ttyS14 /dev/ttyS3 /dev/ttyS6 /dev/ttyS9
/dev/ttyS1 /dev/ttyS12 /dev/ttyS15 /dev/ttyS4 /dev/ttyS7
root@OpenWrt:~# dmesg | grep tty
[ 0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
[ 2.294153] printk: console [ttyS0] disabled
[ 2.303420] 1e000c00.uartlite: ttyS0 at MMIO 0x1e000c00 (irq = 18, base_baud = 3125000) is a 16550A
[ 2.321405] printk: console [ttyS0] enabled
root@OpenWrt:~#
luca, [18/05/25 12:04]
root@OpenWrt:~# cat /sys/kernel/debug/usb/devices
root@OpenWrt:~# opkg list-installed | grep kmod-usb-serial-option
kmod-usb-serial-option - 6.6.73-r1
root@OpenWrt:~# ^C
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~#
root@OpenWrt:~# lsusb
-ash: lsusb: not found
root@OpenWrt:~# lsusb -t
root@OpenWrt:~#
luca, [18/05/25 12:07]
root@OpenWrt:~# opkg update
pkg install uqmiDownloading
Failed to send request: Operation not permitted
*** Failed to download the package list from
D
Downloading
*** Failed to download the package list from https
Downloading s.gz
*** Failed to download the package list from ì
Collected errors:
  • opkg_download: Failed to download 4.
  • opkg_download: Check your network settings and connectivity.
  • opkg_download: Failed to download .
  • opkg_download: Failed to download * opkg_download: Check your network settings and connectivity.
@Tufozz, this is not OpenWrt forum.
ok, i don’t find any help from your last 2 posts.
this is not openwrt.
I can’t help until I see some useful information.
Since you have a Zyxel device, you will need to contact Zyxel for assistance.
since i’m here… i already contacted zyxel and they said it’s a matter of quectel component…
@jfrog thanks for the effort but you are not helping me.
@silvia please help me …
then tell them you bought a complete device from them and not a box full of components
Since you’re using OpenWrt to recover your modem and the modem is not even detected there, I suggest you to raise a question in OpenWrt forum.
Dear @Tufozz
Actually, if your device is Zyxel, it is better to contact with them.
We don’t know why the device didn’t recognize the module.
@silvia You are answering to a wrong person
Dear @jfrog
Thanks for your reminder.
