RM500U-CN latest firmware request
Hi,@Nguyen_Anh
Could you tell me your current firmware version? Thanks.
(post deleted by author)
Hi @leon.bao
My current firmware: RM500UCNAAR01A18M2G_01.001.01.001. I haven’t updated the firmware for a long time.
I accidentally hit the delete button in the topic, so I’m writing this message to you. Sorry!
Hi,@Nguyen_Anh
I have sent to you via private message,pls check.
Tks u very much. However, I’m still having trouble with the 5G NSA connection. I noticed in the group there is a version RM500UCNAAR03A09M2G_01.001.01.001. Could you please provide me with the another latest version?
My imei: 868227051469641
Hi,@Nguyen_Anh
The baseline of your current firmware version is R01. It is not recommended to cross-baseline upgrade to R03, as this carries significant risks.Thank you for your understanding.
Can i have the latest version, these are my hardware details, any QMI or MBIM support?
RM500U-CN
Revision: RM500UCNAAR01A19M2G
RM500UCNAAR01A19M2G_01.001.01.001
Dear @coronas
RM500U doesn’t support QMI and MBIM.
Request: Windows 10 USB Driver for RM500U-CN (MBIM Mode)
Hello Quectel support
I own a Quectel RM500U-CN modem and I am trying to get it working as a network adapter on Windows 10. My issues so far:
AT+QCFG=“usbnet” returns 1 → modem is in MBIM mode
Windows Device Manager shows “CDC ECM” with an error (Code 28: driver not installed) under the network device section
I have tried using available drivers, but none seem compatible or available without logging in
Can someone please share:
  1. The latest Windows 10 USB driver package for RM500U-CN, supporting MBIM mode
  2. Any flashing utility or firmware that ensures full support for MBIM on RM500U-CN
  3. Instructions for installation if special steps are needed
Thank you in advance for your help
Dear @Krystian12
For RM500U, it didn’t support MBIM mode, only ECM and RNDIS.
@silvia I need the latest drivers for windows for RM500U-CNV. I also need to know if Qflash 7.7 can update it or if there’s any other different tool to do it. Thank you
I have sent the latest driver to your email,pls check and try; QFlash v7.7 is the latest and it can upgrade the version
Hello Quectel Team,
I am using RM500U-EA with firmware RM500UEAAAR03A13M2G. The module connects to NR5G-SA (Jio India) but does not obtain an IP address.
Kindly share the latest firmware and QFlash tool for this module.
Thank you.
pls refer to
i have RM500U-CN model (RM500UCNAAR03A05M2G_01.001.01.001) and would like to receive newest frimware, coulkd u help me with that?
kind regards
Dear @gotoguy
Hello Quectel Support,
I would like to request the latest stable firmware specifically compatible with my RM500U-CN R01 module.
Current module information:
Model: RM500U-CN
ATI revision: RM500UCNAAR01A18M2G
AT+QGMR: RM500UCNAAR01A18M2G_01.001.01.001
AT+CSUB: V01
Host: Photonicat / OpenWrt / ARM64 Linux
USB ID: 2c7c:0900
Problem:
After moving between cells or temporarily losing signal, the module may register to 5G again, but data connectivity can remain unavailable for an abnormally long time.
Please provide:
  1. The latest stable firmware for the R01 baseline, preferably RM500UCNAAR01A19M2G or a newer R01 build.
  2. Written confirmation that the package supports upgrading from RM500UCNAAR01A18M2G_01.001.01.001.
  3. Changelog, especially fixes related to cell handover, network registration, PDP/PDU sessions, or data stalls.
  4. Linux ARM64 flashing tool and instructions.
  5. SHA-256 hashes for all supplied files.
  6. The current A18 rollback firmware.
  7. Recovery instructions if the upgrade fails or the module remains in download mode.
Please do not provide R02, R03, RM500U-CNV, or another RM500U hardware variant.
Thank you.
Hi , my current firmware RM500UCNVAAR03A11M2G_01.001.01.001, I would like to ask for software to flash latest firmware and also the latest firmware.
Dear @the3asic
