RM500Q-GL - RRC State logging for 5G SA
I am trying to figure out if it is possible to log and monitor RRC States on the unit i have. I did some looking around and tried to see if i could get this information through AT-Commands but it doesn’t seem so. I have also looked into using QLog (because the 5G hat is connected to a raspberry pi running on Linux). I seem to bet some sort of logs but i am unable to to read/view them because they are formatted in .qmdl . From what i see the only way to open these log file is to use the QXDM tool. Is that correct?
So my questions are:
  1. Does the QLog capture RRC state information?
  2. Can the output of QLog be saved as something other than .qmdl file (something i can read with f.ex Wireshark?)
  3. Is QXDM the only possible option for reading RRC state information?
  4. If we get the QXDM license, how detailed will the logged info be? Will i get all the information regarding RRC state changes? How granular will this be?
  5. Is there any other way that i can get the RRC state information and changes in state?
Thank you in advance!
Dear @Elmir
For Qlog file, it need QXDM to open.
Only with QXDM license, you can check the RRC information. And other network informstion.
