Hi @rspmn ,thankyou for your feedback
yes i configured as you suggested but i still can’t connect to repective APN against that sst value and also how can i configure it for particular plmn_id(“00101”) as you can in picture i have multiple sst values for other plmn_id:90170
+C5GNSSAIRDP: 4,"02.000000"
+C5GNSSAIRDP: "00101",,,1,"01"
+C5GNSSAIRDP: "90170",,,10,"07:02.000032:03:04:05:06:01"
CGDCONT: 1,"IP","5g1","0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 2,"IP","5g1_EMBB","0.0.0.0",0,0,0,0,,,,,,,,1,"01",,,,0
+CGDCONT: 3,"IP","5g2","0.0.0.0",0,0,0,0,,,,,,,,,"",,,,0
+CGDCONT: 4,"IP","5g2_URLLC000000","0.0.0.0",0,0,0,0,,,,,,,,1,"02.000000",,,,0
sudo ./quectel-CM -n 2 -m 1
[05-21_11:19:42:843] QConnectManager_Linux_V1.6.5.1
[05-21_11:19:42:843] Find /sys/bus/usb/devices/2-1 idVendor=0x2c7c idProduct=0x800, bus=0x002, dev=0x003
[05-21_11:19:42:844] Auto find qmichannel = /dev/cdc-wdm0
[05-21_11:19:42:844] Auto find usbnet_adapter = wwan0
[05-21_11:19:42:844] netcard driver = qmi_wwan, driver version = 6.5.0-35-generic
[05-21_11:19:42:844] Modem works in QMI mode
[05-21_11:19:42:880] cdc_wdm_fd = 7
[05-21_11:19:42:964] Get clientWDS = 16
[05-21_11:19:42:996] Get clientDMS = 1
[05-21_11:19:43:028] Get clientNAS = 4
[05-21_11:19:43:060] Get clientUIM = 1
[05-21_11:19:43:092] Get clientWDA = 1
[05-21_11:19:43:123] requestBaseBandVersion RM500QAEAAR11A03M4G
[05-21_11:19:43:252] requestGetSIMStatus SIMStatus: SIM_READY
[05-21_11:19:43:348] requestGetProfile[pdp:2 index:2] 5g1_EMBB///0/IPV4
[05-21_11:19:43:380] requestRegistrationState2 MCC: 1, MNC: 1, PS: Attached, DataCap: 5G_SA
[05-21_11:19:43:412] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[05-21_11:19:43:412] ip addr flush dev wwan0
[05-21_11:19:43:421] ip link set dev wwan0 down
[05-21_11:19:43:860] requestSetupDataCall WdsConnectionIPv4Handle: 0x1f819420
[05-21_11:19:43:988] ip link set dev wwan0 up
[05-21_11:19:43:996] No default.script found, it should be in '/usr/share/udhcpc/' or '/etc//udhcpc' depend on your udhcpc version!
[05-21_11:19:43:996] busybox udhcpc -f -n -q -t 5 -i wwan0
udhcpc: started, v1.30.1
udhcpc: sending discover
udhcpc: sending select for 10.46.0.3
udhcpc: lease of 10.46.0.3 obtained, lease time 7200
[05-21_11:19:44:146] ip -4 address flush dev wwan0
[05-21_11:19:44:151] ip -4 address add 10.46.0.3/29 dev wwan0
[05-21_11:19:44:159] ip -4 route add default via 10.46.0.4 dev wwan0
^C[05-21_11:19:53:556] requestDeactivateDefaultPDP WdsConnectionIPv4Handle
[05-21_11:19:53:620] ip addr flush dev wwan0
[05-21_11:19:53:632] ip link set dev wwan0 down
[05-21_11:19:53:812] QmiWwanThread exit
[05-21_11:19:53:812] qmi_main exit
sudo ./quectel-CM -n 4 -m 2
[05-21_11:20:01:304] QConnectManager_Linux_V1.6.5.1
[05-21_11:20:01:304] Find /sys/bus/usb/devices/2-1 idVendor=0x2c7c idProduct=0x800, bus=0x002, dev=0x003
[05-21_11:20:01:304] Auto find qmichannel = /dev/cdc-wdm0
[05-21_11:20:01:304] Auto find usbnet_adapter = wwan0
[05-21_11:20:01:305] netcard driver = qmi_wwan, driver version = 6.5.0-35-generic
[05-21_11:20:01:305] Modem works in QMI mode
[05-21_11:20:01:340] cdc_wdm_fd = 7
[05-21_11:20:01:428] Get clientWDS = 16
[05-21_11:20:01:460] Get clientDMS = 1
[05-21_11:20:01:492] Get clientNAS = 4
[05-21_11:20:01:524] Get clientUIM = 1
[05-21_11:20:01:556] Get clientWDA = 1
[05-21_11:20:01:587] requestBaseBandVersion RM500QAEAAR11A03M4G
[05-21_11:20:01:716] requestGetSIMStatus SIMStatus: SIM_READY
[05-21_11:20:01:876] requestGetProfile[pdp:4 index:4] 5g2_URLLC000000///0/IPV4
[05-21_11:20:01:908] requestRegistrationState2 MCC: 1, MNC: 1, PS: Attached, DataCap: 5G_SA
[05-21_11:20:01:940] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[05-21_11:20:01:940] ip addr flush dev wwan0
[05-21_11:20:01:945] ip link set dev wwan0 down
[05-21_11:20:01:972] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[05-21_11:20:01:972] call_end_reason is 1
[05-21_11:20:01:972] call_end_reason_type is 2
[05-21_11:20:01:972] call_end_reason_verbose is 265
[05-21_11:20:01:972] try to requestSetupDataCall 5 second later
[05-21_11:20:06:996] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0xe
[05-21_11:20:06:996] call_end_reason is 1
[05-21_11:20:06:996] call_end_reason_type is 2
[05-21_11:20:06:996] call_end_reason_verbose is 265
[05-21_11:20:06:996] try to requestSetupDataCall 10 second later
^C[05-21_11:20:08:468] QmiWwanThread exit
[05-21_11:20:08:468] qmi_main exit
