RG502Q-EA Latest firmware update
dear Herbert can you please send to me all firmware i want to test them all to find the best working ver in my country
my router info:
mikrotik 5g ax
Model RG502Q-EA
Revision RG502QEAAAR13A03M4G
installed: RG502QEAAAR13A03M4G_02.001.02.001
my email: ipade4me@gmail.com
Hi, is there a newer firmware version than RG502QEAAAR13A03M4G_02.001.02.001?, because with this version I have problems with 5G NSA connection and carrier aggregation.
Dear herbert,
Could you please send me the latest Quectel_Linux_PCIE_MHI_Driver? Thanks.
email: cao88yu@gmail.com
Hello Herbert, my firmware is RG502QEAAAR13A03M4G_02.001.02.001, can you please send me a newer one? I am having modem reset and crash problems since my provider changed something in the way my modem connects with certain 5g cells.
Thank you!
email:hatzik@gmail.com
it is the latest version
Hello!
For my NR7102 with modem firmware RG502QEUAAR12A03M4G, please send me the latest firmware.
Hi Herbert
Forgot to add my email, arturo.spain.rodriguez@gmail.com. Thank You
Thank You very much!
dear Herbert ,
can you please send to me all firmware i want to them all to find the best working , and last QFLASHtool ?
Because i have problem in my sim card
my device info:
Dinstar UC2000-VE-8 2g/3g
Model M35
M35AR01A10
My bored
Thanks bro :ribbon:
Hello, tried to update my NR7102 with the firmware file you sent but it fails with a message “illegal firmware”, I tried again after removing SIM card but same result.
5G Modem: Zyxel NR7102
Current modem firmware: RG502QEUAAR12A03M4G
your fimware file: RG502QEUAAR12A03M4G_04.200.04.200
I have MikroTik Chateau 5G ax router with RG502Q-EA modem. I recently received the following firmware: RG502QEAAAR13A03M4G_02.002.02.002
Does anyone have any information about this firmware? Are there any change logs for the firmware updates? Also, how can I see carrier aggregation metrics for uplink?
Dear Herbert, Would you kindly send me every firmware version? I want to test them all to determine which is the best version working in my country.
Mikrotik 5g ax
Model RG502Q-EA
Installed: RG502QEAAAR13A03M4G_02.002.02.002
ashaari777@gmail.com
Greetings,
I am looking for the latest firmware RG502QEAAAR13A03M4G_02.002.02.002 as well. I would really appreciate if you could send it to me as well. Thank you for your time and consideration!
Apparently there’s a RG502QEAAAR13A03M4G_02.003.02.003 now.
Can you please send us this firmware? @herbert.pan-Q
