RG255C-GL QFirehose fail to update from R01A04
Dear Quectel support team,
I am trying to update my modem:
ati
RG255C-GL
Revision: RG255CGLABR01A04M4G
To version R01A05 using QFirehose 1.5.1.
Eveytime we test, the process stops in the same step:
root@root:~# QFirehose -f /mntDAT/rg255cglab/
[000.000]: Version: QFirehose_Linux_Android_V1.5.1
[000.000]: Builded: Jun 25 2025 02:49:36
[000.000]: Find md5 check file </mntDAT/rg255cglab/md5.txt>
[000.000]: md5 checking: /mntDAT/rg255cglab/contents.xml pass
[000.004]: md5 checking: /mntDAT/rg255cglab/update/abl.elf pass
[000.004]: md5 checking: /mntDAT/rg255cglab/update/aop_devcfg.mbn pass
[000.005]: md5 checking: /mntDAT/rg255cglab/update/aop.mbn pass
[000.005]: md5 checking: /mntDAT/rg255cglab/update/apdp.mbn pass
[000.052]: md5 checking: /mntDAT/rg255cglab/update/boot.img pass
[000.056]: md5 checking: /mntDAT/rg255cglab/update/cmnlib.mbn pass
[000.056]: md5 checking: /mntDAT/rg255cglab/update/cpucp.elf pass
[000.056]: md5 checking: /mntDAT/rg255cglab/update/devcfg.mbn pass
[000.057]: md5 checking: /mntDAT/rg255cglab/update/firehose/partition_complete_p2K_b128K.mbn pass
[000.057]: md5 checking: /mntDAT/rg255cglab/update/firehose/patch_p2K_b128K.xml pass
[000.066]: md5 checking: /mntDAT/rg255cglab/update/firehose/prog_firehose_sdx35.elf pass
[000.066]: md5 checking: /mntDAT/rg255cglab/update/firehose/rawprogram_nand_p2K_b128K_update.xml pass
[000.067]: md5 checking: /mntDAT/rg255cglab/update/fw_ipa_gsi_5.2_le.elf pass
[000.068]: md5 checking: /mntDAT/rg255cglab/update/km41_32.mbn pass
[000.069]: md5 checking: /mntDAT/rg255cglab/update/multi_qti.mbn pass
[000.353]: md5 checking: /mntDAT/rg255cglab/update/NON-HLOS.ubi pass
[000.354]: md5 checking: /mntDAT/rg255cglab/update/partition.mbn pass
[000.354]: md5 checking: /mntDAT/rg255cglab/update/partition_nand.xml pass
[000.381]: md5 checking: /mntDAT/rg255cglab/update/qdsp6m.qdb pass
[000.382]: md5 checking: /mntDAT/rg255cglab/update/qupv3fw.elf pass
[000.445]: md5 checking: /mntDAT/rg255cglab/update/recoveryfs.ubi pass
[000.445]: md5 checking: /mntDAT/rg255cglab/update/shrm.elf pass
[000.873]: md5 checking: /mntDAT/rg255cglab/update/sysfs.ubi pass
[000.881]: md5 checking: /mntDAT/rg255cglab/update/tz.mbn pass
[000.899]: md5 checking: /mntDAT/rg255cglab/update/uefi.elf pass
[000.901]: md5 checking: /mntDAT/rg255cglab/update/usrdata.ubi pass
[000.902]: md5 checking: /mntDAT/rg255cglab/update/xbl_config.elf pass
[000.905]: md5 checking: /mntDAT/rg255cglab/update/xbl_ramdump.elf pass
[000.912]: md5 checking: /mntDAT/rg255cglab/update/xbl_s_nand.melf pass
[000.912]: Totals checking 30 files md5 value, 0 file fail!
[000.912]: find ‘prog_firehose_sdx35.elf’
[000.912]: find_firehose_mbn prog_firehose_sdx35.elf
[000.912]: main prog_firehose_sdx35.elf
[000.912]: [1] /sys/bus/usb/devices/3-1.2 5c6/9008/0
[000.913]: qusb_read_speed_atime speed: 480, st_atime: 20260521_11:10:23
[000.913]: P: /dev/bus/usb/003/016 idVendor=05c6 idProduct=9008
[000.913]: C: /dev/bus/usb/003/016 bNumInterfaces: 1
[000.913]: I: If#= 0 Alt= 0 #EPs= 2 Cls=ff Sub=ff Prot=11
[000.913]: E: Ad=81 Atr=02 MxPS= 512 Ivl=0ms
[000.913]: E: Ad=01 Atr=02 MxPS= 512 Ivl=0ms
[000.913]: tmp=/sys/bus/usb/devices/usb3/../driver, driver=../../../../../../bus/platform/drivers/xhci-hcd
[000.913]: usbfs_is_kernel_driver_alive find interface 0 has match the driver qcserial
[000.927]: usbfs_detach_kernel_driver detach kernel driver success
[000.927]: <=== Q_SAHARA_ONE
[000.927]: Q_SAHARA_TWO ===>
[000.934]: <=== Q_SAHARA_EIGHTEEN
[000.934]: 0x0000000d 0x00000000 0x00000040
[000.934]: 0x0000000d 0x00000034 0x00000040
[000.935]: <=== Q_SAHARA_EIGHTEEN
[000.935]: 0x0000000d 0x00000074 0x00001000
[000.966]: <=== Q_SAHARA_EIGHTEEN
[000.966]: 0x0000000d 0x00001074 0x0000028c
[000.972]: <=== Q_SAHARA_EIGHTEEN
[000.972]: 0x0000000d 0x00001300 0x00000040
[000.972]: 0x0000000d 0x00001334 0x00000180
[000.972]: 0x0000000d 0x0002d300 0x00002eb0
[000.983]: <=== Q_SAHARA_EIGHTEEN
[000.983]: 0x0000000d 0x00002000 0x00011000
Would you please help us on how to move on with the update process?
Thanks and kind regards.
Dear @pgrobledo
I have sent newer version to you via Message, please check.
