Restoring USB access after disabling it through AT comman
Hi every body,
Due to cyber security reasons I tested to disable the USB port using AT command AT+QCFGEXT=“disusb” (with commad 1 , I think). The device works as expected and the USB port disappeared.
My question is if it is possible to re-enable the USB port back to its original operation mode so that a new/updated application firmware may be loaded?
I managed to get the device into “emergency download mode” (using the USB boot pin) and reload modem firmwware but that did not restore the normal USB port operation.
hello, could you please tell us your current module type or firmware? thank you~
I am trying this on a BG95-M5 modulle.
Cheers
@Linkin-Q add linkin to support this issue, thanks~
