Hello Quectel,
I am using the RG530F-EU with 5G-mmWave_EVB.
If there is a newer version of the firmware available, I would greatly appreciate it if you could provide it.
grep94@naver.com
Thanks.
AT+QGMR
RG530FEUEAR05A02M8G_01.200.01.200
ATI
RG530F-EU
Revision: RG530FEUEAR05A02M8G
Hi,@rachtec
I have sent to you via private message,pls check
Thank you very much for your prompt response to my request.
Additionally, I need information regarding mmWave antenna control on the RG530F-EU.
In particular, I am using the commands AT+QMMWSCAN and AT+QMMWENABLE.
If there is a document that contains additional AT commands related to this functionality, I would greatly appreciate it if you could provide it.
After upgrading to the firmware version RG530FEUEAR05A04M8G you provided, I found that I can no longer configure bands 257 and 261 in 5G NR SA mode.
However, I must be able to use bands 257 and 261 in 5G NR SA mode.
If I downgrade the firmware to RG530FEUEAR05A03M8G, will the command
AT+QNWPREFCFG=“nr5g_band”,257:261
work again?
I would appreciate it if you could advise me on a solution.
Hi leon.bao
I would also like to request the firmware file for the following version:
- RG530FEUEAR05A03M8G 01.200.01.200
Thank you very much for your support.
