Hi, can I get a lastst firmwae for EC20CEHCLG-128-AUD?
My current version is EC20CEHCLGR06A02M1G_AUD, but it doesn’t work,only Quectel USB DM Port
My email: yeye@post.com
Thanks!
Thanks!
Hi there,
Could you please confirm on the below questions:
You can install the driver below for this module:
Quectel_Windows_USB_Driver(Q)_NDIS_V2.8_EN.zip
Attached the latest firmware as per requested:
EC20CEHCLGR06A05M1G.zip
Thank you for your reply.
It’s not a problem with the driver; the module is now working properly.
I used the AT command (AT+QCFG=“usbcfg”) to compare the output results of ec20cefag and ec20cehclg.
Then, set ec20cehclg to have the same parameters as ec20cefag. Now, it works properly.
AT+GMR
EC20CEHCLGR06A02M1G_AUDOK
AT+QCFG=“usbcfg”
+QCFG: “usbcfg”,0x2C7C,0x0125,0,0,1,0,0,0,0OK
AT+CGMR
EC20CEFAGR08A03M4G
AT+QCFG=“usbcfg”
+QCFG: “usbcfg”,0x2C7C,0x0125,1,1,1,1,1,0,0
Thanks for providing the latest firmware.
Hi there,
Most Welcome.
Hi, Can you share me this firmware? I get the same version module EC20CEHCLGR06A02M1G_AUD
I want to latest firmware.
Hi @X_ng_Bui
I will send you a follow up email to your email address. Kindly check on your side.
