Request for Support – AT Command Response Issue on EC800M
Dear Quectel Support Team,
I am currently working with the EC800M module.
When I send AT commands via UART from my PC, I receive incomplete responses.
For details, please check the log file.
AT command error EG800M.txt (111 Bytes)
Here are the details of my setup:
  • Module: EC800M
  • Firmware version: EC800MCNGDR06A04M04
Could you please advise me on why this issue occurs and how to resolve it?
Thank you very much for your support.
Best regards,
Dai Ho
I suggest you try again using another TTL (USB to UART) converter.
good moring @herbert.pan-Q
I have tested with all the USB-to-TTL modules available to me, but the result remains the same. Therefore, I believe the issue might be with the EC800M module.
Could you print more AT logs?
AT_MQTT_SSL_Error.txt (1.3 KB)
This is the log when I established the MQTT connection. Please check.
The current firmware in the module is EC800MCNGDR06A04M04. Could you please send me the latest firmware?
my email: hohuydai@ginno.com
@herbert.pan-Q please help me
EC800MCNGD no support MQTTs
check message herbert i need help regarding commands @herbert.pan-Q
