Request for PDF manuals for RM520N-GL module
Sir,
Request to send documents for the mentioned device as follows…
  • GPS
  • TCP/IP
  • File IO
  • Network Scan
  • AT
A humble suggestion is to create a central repo of documents, firmwares at one place. Because most the time everyboyd is requesting for same files.
Regards
Dear @ketan.asm ,
Thank You for reaching out with your query,
*A humble suggestion is to create a central repo of documents, firmwares at one place. Because most the time everyboyd is requesting for same files.
Definalety we will try to adress this issue, as for now the documents are provided upon request.
Thank You and Have a great Day!
Dear Alvin,
Thank you so much for the documents, they were really very useful to me.
One more humble request to you regarding NSA network scanning using AT+QSCAN command.
The firmware release notes ‘RM520NGLAAR03A03M4G_A0.300.A0.300’ says that…
NETWORK Extended AT+QSCAN to support scanning NSA network.
Can you please explain how to do it?
Regards
Thanks in advance
Dear @ketan.asm
As checked internally, it is a customized feature, in standard firmware, it doesn’t support.
Sorry for this.
