Request for latest firmware and flashing tools for RM500U-EA
Dear Quectel Support,
I have a Quectel RM500U-EA module (version RM500UEAAA-D10-SNADA) installed on my Debian 12 system.
I would like to request the latest firmware (RM500UEAAAR03A06M2G_01.001.01.001) and the proper tools to reflash it.
Could you please send the firmware and flashing tool to my registered email address?
I have sent you the latest firmware version and the upgrade tool. Please check it.
Thank you for the files.
After flashing the .pac version, my RM500U-EA no longer registers on LTE/5G and shows “sprd” as firmware.
Could you please confirm if I should use the Qualcomm QFIL version (RM500UEAAAR03A06M2G_01.001.01.001_FULL) instead?
Dear @Deposito
RM500U is Unisoc platform. It can’t use QFIL. How did you flash the firmware?
Please check AT+CFUN?
I am using the RM500U-EA module on lightweight ARM-based systems running Linux (for example, Debian 12 / Kali).
Currently, the module only exposes serial (ttyUSB) interfaces and does not create /dev/cdc-wdm0 even after switching usbnet modes.
Could you please provide the latest firmware that enables MBIM or QMI functionality on ARM platforms (not only x86_64)?
I would like to use the module with single-board computers and embedded Linux environments.
Thank you for your support.
Dear @Deposito
RM500U doesn’t support MBIM.
QMI is Qualcomm, but RM500U is Unisoc platform.
So RM500U doesn’t support these feature.
Dear Silvia,
Thank you for clarifying that the RM500U-EA is based on the Unisoc platform.
The module is working properly; however, it currently relies on 4G as the primary link,
while 5G is active only in NSA mode. The 4G speed is very slow even though the signal is strong (RSRP = –74 dBm).
Below are the network readings:
+QENG: “LTE”,“FDD”,420,01,358C82F,429,1450,3,5,5,1B9E,-74,-10,-45,8,0,0,46
+QENG: “NR5G-NSA”,4
Could you please help me configure the module so that 5G (NR) becomes the primary connection
instead of 4G?
Dear @Deposito
Sorry, module can’t do this, you can check with your operator and see whether they configure 5G as primary.
Actually, NSA is based 4G,
can I request also for the latest firmware and tools using windows
Dear @joshua-garcia
Dear @knights19
