Quectel RG255C-GL on Linux 6.6.40
I try to install
Product: RG255C-GL
SerialNumber: ad1ad481
I have followed the information in the RG255C-GL for Linux 6.1.0 and it doesn’t help me.
I have a Kernel 6.6.40
Modules Kernel : sources Quectel v6.6.11 or v6.7.5 (modules option, qcserial, usb_wwan, usbserial)
Application Quectel : QConnectManager_Linux_V1.6.4
[11-28_14:47:31:715] network interface ‘’ or qmidev ‘’ is not exist
[11-28_14:47:31:715] atdevice_detect failed
[11-28_14:47:31:715] qmidevice_detect failed
Below the results returned
Any Idea for helping ?
The result
Lsmod :
option 57344 0
qcserial 16384 0
usb_wwan 12288 2 qcserial,option
usbserial 36864 3 qcserial,usb_wwan,option
quectel-CMin debug mode gives :
[11-28_14:47:31:709] (/sys/bus/usb/devices/1-3.2/idVendor) = 2c7c
[11-28_14:47:31:710] (/sys/bus/usb/devices/1-3.2/idProduct) = 316
[11-28_14:47:31:710] (/sys/bus/usb/devices/1-3.2/busnum) = 1
[11-28_14:47:31:710] (/sys/bus/usb/devices/1-3.2/devnum) = 5
[11-28_14:47:31:710] (/sys/bus/usb/devices/1-3.2/bNumInterfaces) = 4
[11-28_14:47:31:710] Find /sys/bus/usb/devices/1-3.2 idVendor=0x2c7c idProduct=0x316, bus=0x001, dev=0x005
[11-28_14:47:31:711] (/sys/bus/usb/devices/1-3/idVendor) = 1a40
[11-28_14:47:31:711] (/sys/bus/usb/devices/1-3/idProduct) = 101
[11-28_14:47:31:711] (/sys/bus/usb/devices/1-3/busnum) = 1
[11-28_14:47:31:712] (/sys/bus/usb/devices/1-3/devnum) = 2
[11-28_14:47:31:712] (/sys/bus/usb/devices/1-3/bNumInterfaces) = 1
[11-28_14:47:31:712] (/sys/bus/usb/devices/1-3.1/idVendor) = 1a86
[11-28_14:47:31:713] (/sys/bus/usb/devices/1-3.1/idProduct) = 7523
[11-28_14:47:31:713] (/sys/bus/usb/devices/1-3.1/busnum) = 1
[11-28_14:47:31::13] (/sys/bus/usb/devices/1-3.1/devnum) = 4
[11-28_14:47:31:713] (/sys/bus/usb/devices/1-3.1/bNumInterfaces) = 1
[11-28_14:47:31:714] (/sys/bus/usb/devices/1-4/idVendor) = 1a86
[11-28_14:47:31:714] (/sys/bus/usb/devices/1-4/idProduct) = 7523
[11-28_14:47:31:714] (/sys/bus/usb/devices/1-4/busnum) = 1
[11-28_14:47:31:714] (/sys/bus/usb/devices/1-4/devnum) = 3
[11-28_14:47:31:715] (/sys/bus/usb/devices/1-4/bNumInterfaces) = 1
Lsusb -v gives :
Bus 001 Device 005: ID 2c7c:0316
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2c7c
idProduct 0x0316
bcdDevice 5.15
iManufacturer 1 Quectel
iProduct 2 RG255C-GL
iSerial 3 ad1ad481
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 134
bNumInterfaces 4
bConfigurationValue 1
iConfiguration 4 DIAG_SER_RMNET_AUDIO
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
Modinfo option :
modinfo option
filename: /lib/modules/6.6.40/kernel/drivers/usb/serial/option.ko
license: GPL v2
description: USB Driver for GSM modems
Modinfo qcserial
filename: /lib/modules/6.6.40/kernel/drivers/usb/serial/qcserial.ko
license: GPL v2
description: Qualcomm USB Serial driver
author: Qualcomm Inc
Modinfo usb_wwan :
filename: /lib/modules/6.6.40/kernel/drivers/usb/serial/usb_wwan.ko
license: GPL v2
depends: usbserial
retpoline: Y
vermagic: 6.6.40 SMP mod_unload
Modinfo usbserial
filename: /lib/modules/6.6.40/kernel/drivers/usb/serial/usbserial.ko
license: GPL v2
description: USB Serial Driver core
retpoline: Y
intree: Y
Thank you
Please show
lsusb -t
RG255C_quectel-CM
I’ve tried all the commands showed in the video with no results
below the results of the commands and my remarks
lsusb -t :
: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 5000M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/6p, 480M
|__ Port 3: Dev 2, If 0, Class=, Driver=hub/4p, 480M
|__ Port 1: Dev 4, If 0, Class=, Driver=, 12M
    |__ Port 2: Dev 5, If 0, Class=, Driver=option, 480M
    |__ Port 2: Dev 5, If 1, Class=, Driver=option, 480M
    |__ Port 2: Dev 5, If 2, Class=, Driver=option, 480M
    |__ Port 2: Dev 5, If 3, Class=, Driver=, 480M
|__ Port 4: Dev 3, If 0, Class=, Driver=, 12M
lsmod results
qcserial 16384 0
option 57344 0
xt_ndpi 1085440 0
xhci_plat_hcd 12288 0
xhci_pci 16384 0
xhci_hcd 151552 2 xhci_pci,xhci_plat_hcd
ehci_platform 12288 0
uhci_hcd 32768 0
ohci_platform 12288 0
ohci_pci 12288 0
ehci_pci 12288 0
ohci_hcd 40960 2 ohci_platform,ohci_pci
ehci_hcd 57344 2 ehci_platform,ehci_pci
pppoe 16384 0
pppox 12288 1 pppoe
bsd_comp 12288 0
ppp_deflate 12288 0
ppp_synctty 12288 0
ppp_async 16384 0
ppp_mppe 12288 0
iwlwifi 307200 0
ath10k_pci 49152 0
ath10k_core 536576 1 ath10k_pci
ath 28672 1 ath10k_core
mt7915e 167936 0
mt76_connac_lib 57344 1 mt7915e
mt76 77824 2 mt7915e,mt76_connac_lib
mac80211 794624 4 mt76,mt7915e,mt76_connac_lib,ath10k_core
libarc4 12288 2 ppp_mppe,mac80211
cfg80211 442368 7 mt76,mt7915e,ath,iwlwifi,mac80211,mt76_connac_lib,ath10k_core
i40e 409600 0
atlantic 196608 0
ixgbe 311296 0
mdio 12288 1 ixgbe
pcnet32 45056 0
8139too 28672 0
8139cp 28672 0
r8169 81920 0
realtek 32768 0
e1000 114688 0
e1000e 221184 0
tg3 184320 0
igb 208896 0
hwmon 16384 6 atlantic,tg3,igb,mt7915e,ath10k_core,ixgbe
ptp 32768 6 i40e,atlantic,tg3,igb,e1000e,ixgbe
pps_core 12288 1 ptp
The interface wwan0 is present
wwan0: flags=209<UP,POINTOPOINT,RUNNING,NOARP> mtu 1500
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 1000 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
quectel-CM error is still present:
[12-03_15:28:27:921] QConnectManager_Linux_V1.6.4
[12-03_15:28:27:923] Find /sys/bus/usb/devices/1-3.2 idVendor=0x2c7c idProduct=0x316, bus=0x001, dev=0x005
[12-03_15:28:27:926] network interface ‘’ or qmidev ‘’ is not exist
[12-03_15:28:27:926] atdevice_detect failed
[12-03_15:28:27:926] qmidevice_detect failed
A major different with the video is that the device /dev/cdc-wdcm0 is not present.
thank you
There are two problems from your log.
  1. You should try the quectel-CM later than 1.6.7.
  2. You need the qmi_wwan_q driver.
    I have sent them.
Thank you,
Now the 5G board is detected. I notice that the interface is not wwan0 (as the 4G board) but wwan2 is it normal ?
The dmesg gives
[ 65.467186] qmi_wwan_q: loading out-of-tree module taints kernel.
[ 65.471978] qmi_wwan_q 1-3.2:1.3: cdc-wdm0: USB WDM device
[ 65.472414] wwan wwan2: port wwan2qmi0 attached
[ 65.473887] qmi_wwan_q 1-3.2:1.3: Quectel RG255C-GL work on RawIP mode
[ 65.475532] qmi_wwan_q 1-3.2:1.3: rx_urb_size = 16384
[ 65.476330] qmi_wwan_q 1-3.2:1.3 wwan2: register ‘qmi_wwan_q’ at usb-0000:00:14.0-3.2, WWAN/QMI Raw IP device, fe:eb:23:6f:14:11
[ 65.476547] usbcore: registered new interface driver qmi_wwan_q
[ 67.900034] net wwan2: ul_data_aggregation_max_datagrams=11, ul_data_aggregation_max_size=8192, dl_minimum_padding=0
[ 68.283567] net wwan2: link_state 0x0 → 0x1
Please send the complete log.
All the differents logs
lsusb -v
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2c7c
idProduct 0x0316
bcdDevice 5.15
iSerial 3 ad1ad481
bLength 9
bDescriptorType 2
wTotalLength 134
bNumInterfaces 4
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bInterfaceSubClass 255
bInterfaceProtocol 48
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255
bInterfaceProtocol 64
iInterface 6 CDEV Serial
** UNRECOGNIZED: 05 24 00 10 01
** UNRECOGNIZED: 05 24 01 00 00
** UNRECOGNIZED: 04 24 02 02
** UNRECOGNIZED: 05 24 06 00 00
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x000a 1x 10 bytes
bInterval 9
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255
bInterfaceProtocol 80
iInterface 7 RmNet
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 9
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 5000M
|__ Port 2: Dev 5, If 0, Class=, Driver=, 480M
|__ Port 2: Dev 5, If 1, Class=, Driver=, 480M
|__ Port 2: Dev 5, If 2, Class=, Driver=, 480M
|__ Port 2: Dev 5, If 3, Class=, Driver=qmi_wwan_q, 480M
Ltelog file
[12-05_11:39:23:950] (/sys/bus/usb/devices/1-3.2/idVendor) = 2c7c
[12-05_11:39:23:951] (/sys/bus/usb/devices/1-3.2/idProduct) = 316
[12-05_11:39:23:951] (/sys/bus/usb/devices/1-3.2/busnum) = 1
[12-05_11:39:23:951] (/sys/bus/usb/devices/1-3.2/devnum) = 5
[12-05_11:39:23:951] (/sys/bus/usb/devices/1-3.2/bNumInterfaces) = 4
[12-05_11:39:23:951] Find /sys/bus/usb/devices/1-3.2 idVendor=0x2c7c idProduct=0x316, bus=0x001, dev=0x005
[12-05_11:39:23:952] (/sys/bus/usb/devices/1-3.2:1.3/bNumEndpoints) = 3
[12-05_11:39:23:952] (/sys/bus/usb/devices/1-3.2:1.3/bInterfaceClass) = ff
[12-05_11:39:23:952] (/sys/bus/usb/devices/1-3.2:1.3/bInterfaceSubClass) = ff
[12-05_11:39:23:952] (/sys/bus/usb/devices/1-3.2:1.3/bInterfaceProtocol) = 50
[12-05_11:39:23:953] driver → ../../../../../../../bus/usb/drivers/qmi_wwan_q
[12-05_11:39:23:953] /sys/bus/usb/devices/1-3.2:1.3/usbmisc
[12-05_11:39:23:953] Auto find qmichannel = /dev/cdc-wdm0
[12-05_11:39:23:953] Auto find usbnet_adapter = wwan2
[12-05_11:39:23:953] netcard driver = qmi_wwan_q, driver version = V1.2.9
[12-05_11:39:23:954] qmap_mode = 1, qmap_version = 5, qmap_size = 16384, muxid = 0x81, qmap_netcard = wwan2
[12-05_11:39:23:954] Modem works in QMI mode
[12-05_11:39:23:964] cdc_wdm_fd = 8
[12-05_11:39:23:964] 01 0b 00 00 00 00 00 01 27 00 00 00
[12-05_11:39:23:964] TransactionId: 01
QMICTLType: 0027 QMICTL_SYNC_REQ
Length: 0000
[12-05_11:39:24:967] QmiWwanInit message timeout
[12-05_11:39:25:968] 01 0b 00 00 00 00 00 02 27 00 00 00
[12-05_11:39:25:968] TransactionId: 02
Length: 0000
[12-05_11:39:25:988] 01 0b 00 80 00 00 02 00 27 00 00 00
[12-05_11:39:25:988] TransactionId: 00
QMICTLType: 0027 QMICTL_SYNC_IND
Length: 0000
[12-05_11:39:25:988] nobody care this qmi msg!!
[12-05_11:39:26:020] 01 12 00 80 00 00 01 01 27 00 07 00 02 04 00 00 00 00 00
[12-05_11:39:26:021] TransactionId: 01
QMICTLType: 0027 QMICTL_SYNC_RESP
Length: 0007
{02, 0004, 00 00 00 00 }
[12-05_11:39:26:021] nobody care this qmi msg!!
[12-05_11:39:26:052] 01 12 00 80 00 00 01 02 27 00 07 00 02 04 00 00 00 00 00
[12-05_11:39:26:052] TransactionId: 02
Length: 0007
[12-05_11:39:26:053] 01 0f 00 00 00 00 00 03 21 00 04 00 01 01 00 ff
[12-05_11:39:26:053] TransactionId: 03
QMICTLType: 0021 QMICTL_GET_VERSION_REQ
Length: 0004
{01, 0001, ff }
[12-05_11:39:26:085] 01 b6 00 80 00 00 01 03 21 00 ab 00 02 04 00 00 00 00 00 01 a1 00 20 00 01 00 05 00 01 01 00 f8 00 02 01 00 57 00 03 01 00 19 00 04 01 00 15 00 05 01 00 0a 00 08 01 00 06 00 09 02 00 01 00 0a 02 00 18 00 0b 01 00 4d 00 0c 01 00 04 00 0f 01 00 00 00 10 02 00 a6 00 11 01 00 00 00 12 01 00 6b 00 14 01 00 00 00 17 02 00 00 00 18 01 00 00 00 1a 01 00 1d 00 21 01 00 31 00 22 01 00 00 00 24 01 00 00 00 29 01 00 00 00 2a 01 00 50 00 2d 01 00 00 00 30 01 00 11 00 31 01 00 00 00 44 01 00 07 00 4c 01 00 00 00 4d 01 00 05 00 4e 01 00 02 00 55 01 00 00 00
[12-05_11:39:26:086] TransactionId: 03
QMICTLType: 0021 QMICTL_GET_VERSION_RESP
Length: 00ab
{01, 00a1, 20 00 01 00 05 00 01 01 00 f8 00 02 01 00 57 00 03 01 00 19 00 04 01 00 15 00 05 01 00 0a 00 08 01 00 06 00 09 02 00 01 00 0a 02 00 18 00 0b 01 00 4d 00 0c 01 00 04 00 0f 01 00 00 00 10 02 00 a6 00 11 01 00 00 00 12 01 00 6b 00 14 01 00 00 00 17 02 00 00 00 18 01 00 00 00 1a 01 00 1d 00 21 01 00 31 00 22 01 00 00 00 24 01 00 00 00 29 01 00 00 00 2a 01 00 50 00 2d 01 00 00 00 30 01 00 11 00 31 01 00 00 00 44 01 00 07 00 4c 01 00 00 00 4d 01 00 05 00 4e 01 00 02 00 55 01 00 00 00 }
[12-05_11:39:26:086] 01 0f 00 00 00 00 00 04 22 00 04 00 01 01 00 01
[12-05_11:39:26:086] TransactionId: 04
QMICTLType: 0022 QMICTL_GET_CLIENT_ID_REQ
Length: 0004
{01, 0001, 01 }
[12-05_11:39:26:116] 01 17 00 80 00 00 01 04 22 00 0c 00 02 04 00 00 00 00 00 01 02 00 01 09
[12-05_11:39:26:116] TransactionId: 04
QMICTLType: 0022 QMICTL_GET_CLIENT_ID_RESP
Length: 000c
{01, 0002, 01 09 }
[12-05_11:39:26:117] Get clientWDS = 9
[12-05_11:39:26:117] 01 0f 00 00 00 00 00 05 22 00 04 00 01 01 00 02
[12-05_11:39:26:117] TransactionId: 05
Length: 0004
{01, 0001, 02 }
[12-05_11:39:26:148] 01 17 00 80 00 00 01 05 22 00 0c 00 02 04 00 00 00 00 00 01 02 00 02 01
[12-05_11:39:26:148] TransactionId: 05
Length: 000c
{01, 0002, 02 01 }
[12-05_11:39:26:149] Get clientDMS = 1
[12-05_11:39:26:149] 01 0f 00 00 00 00 00 06 22 00 04 00 01 01 00 03
[12-05_11:39:26:149] TransactionId: 06
Length: 0004
{01, 0001, 03 }
[12-05_11:39:26:180] 01 17 00 80 00 00 01 06 22 00 0c 00 02 04 00 00 00 00 00 01 02 00 03 03
[12-05_11:39:26:180] TransactionId: 06
Length: 000c
{01, 0002, 03 03 }
[12-05_11:39:26:181] Get clientNAS = 3
[12-05_11:39:26:181] 01 0f 00 00 00 00 00 07 22 00 04 00 01 01 00 0b
[12-05_11:39:26:181] TransactionId: 07
Length: 0004
{01, 0001, 0b }
[12-05_11:39:26:212] 01 17 00 80 00 00 01 07 22 00 0c 00 02 04 00 00 00 00 00 01 02 00 0b 02
[12-05_11:39:26:213] TransactionId: 07
Length: 000c
{01, 0002, 0b 02 }
[12-05_11:39:26:213] Get clientUIM = 2
[12-05_11:39:26:213] 01 0f 00 00 00 00 00 08 22 00 04 00 01 01 00 1a
[12-05_11:39:26:213] TransactionId: 08
Length: 0004
{01, 0001, 1a }
[12-05_11:39:26:244] 01 17 00 80 00 00 01 08 22 00 0c 00 02 04 00 00 00 00 00 01 02 00 1a 01
[12-05_11:39:26:244] TransactionId: 08
Length: 000c
{01, 0002, 1a 01 }
[12-05_11:39:26:244] Get clientWDA = 1
[12-05_11:39:26:245] 01 0c 00 00 02 00 00 01 00 23 00 00 00
[12-05_11:39:26:245] TransactionId: 0001
Type: 0023 QMIDMS_GET_DEVICE_REV_ID_REQ
Length: 0000
[12-05_11:39:26:276] 01 29 00 80 02 01 02 01 00 23 00 1d 00 02 04 00 00 00 00 00 01 13 00 52 47 32 35 35 43 47 4c 41 42 52 30 31 41 30 34 4d 34 47
[12-05_11:39:26:277] TransactionId: 0001
Type: 0023 QMIDMS_GET_DEVICE_REV_ID_RESP
Length: 001d
{01, 0013, 52 47 32 35 35 43 47 4c 41 42 52 30 31 41 30 34 4d 34 47 }
[12-05_11:39:26:277] requestBaseBandVersion RG255CGLABR01A04M4G
[12-05_11:39:26:277] 01 53 00 00 1a 00 00 02 00 20 00 47 00 10 01 00 00 11 04 00 02 00 00 00 12 04 00 05 00 00 00 13 04 00 05 00 00 00 15 04 00 20 00 00 00 16 04 00 00 40 00 00 17 08 00 02 00 00 00 03 00 00 00 19 04 00 00 00 00 00 1b 04 00 0b 00 00 00 1c 04 00 00 20 00 00
[12-05_11:39:26:277] TransactionId: 0002
Type: 0020 QMIWDS_ADMIN_SET_DATA_FORMAT_REQ
Length: 0047
{10, 0001, 00 }
{11, 0004, 02 00 00 00 }
{12, 0004, 05 00 00 00 }
{13, 0004, 05 00 00 00 }
{15, 0004, 20 00 00 00 }
{16, 0004, 00 40 00 00 }
{17, 0008, 02 00 00 00 03 00 00 00 }
{19, 0004, 00 00 00 00 }
{1b, 0004, 0b 00 00 00 }
{1c, 0004, 00 20 00 00 }
[12-05_11:39:26:309] 01 5a 00 80 1a 01 02 02 00 20 00 4e 00 02 04 00 00 00 00 00 10 01 00 00 11 04 00 02 00 00 00 12 04 00 05 00 00 00 13 04 00 05 00 00 00 14 04 00 00 00 00 00 15 04 00 20 00 00 00 16 04 00 00 40 00 00 17 04 00 0b 00 00 00 18 04 00 00 20 00 00 1a 04 00 00 00 00 00 1b 01 00 00
[12-05_11:39:26:309] TransactionId: 0002
Type: 0020 QMIWDS_ADMIN_SET_DATA_FORMAT_RESP
Length: 004e
{10, 0001, 00 }
{14, 0004, 00 00 00 00 }
{17, 0004, 0b 00 00 00 }
{18, 0004, 00 20 00 00 }
{1a, 0004, 00 00 00 00 }
{1b, 0001, 00 }
[12-05_11:39:26:309] qmap_settings.rx_urb_size = 16384
[12-05_11:39:26:309] qmap_settings.ul_data_aggregation_max_datagrams = 11
[12-05_11:39:26:309] qmap_settings.ul_data_aggregation_max_size = 8192
[12-05_11:39:26:309] qmap_settings.dl_minimum_padding = 0
[12-05_11:39:26:310] 01 22 00 00 01 00 00 03 00 a2 00 16 00 10 08 00 02 00 00 00 03 00 00 00 11 01 00 81 13 04 00 01 00 00 00
[12-05_11:39:26:310] TransactionId: 0003
Type: 00a2 QMIWDS_BIND_MUX_DATA_PORT_REQ
Length: 0016
{10, 0008, 02 00 00 00 03 00 00 00 }
{11, 0001, 81 }
{13, 0004, 01 00 00 00 }
[12-05_11:39:26:340] 01 13 00 80 01 09 02 03 00 a2 00 07 00 02 04 00 00 00 00 00
[12-05_11:39:26:340] TransactionId: 0003
Type: 00a2 QMIWDS_BIND_MUX_DATA_PORT_RESP
Length: 0007
[12-05_11:39:26:341] 01 10 00 00 01 00 00 04 00 4d 00 04 00 01 01 00 04
[12-05_11:39:26:341] TransactionId: 0004
Type: 004d QMIWDS_SET_CLIENT_IP_FAMILY_PREF_REQ
Length: 0004
{01, 0001, 04 }
[12-05_11:39:26:372] 01 13 00 80 01 09 02 04 00 4d 00 07 00 02 04 00 00 00 00 00
[12-05_11:39:26:372] TransactionId: 0004
Type: 004d QMIWDS_SET_CLIENT_IP_FAMILY_PREF_RESP
Length: 0007
[12-05_11:39:26:373] 01 10 00 00 01 00 00 05 00 51 00 04 00 01 01 00 00
[12-05_11:39:26:373] TransactionId: 0005
Type: 0051 QMIWDS_SET_AUTO_CONNECT_REQ
Length: 0004
{01, 0001, 00 }
[12-05_11:39:26:404] 01 13 00 80 01 09 02 05 00 51 00 07 00 02 04 00 01 00 1a 00
[12-05_11:39:26:405] TransactionId: 0005
Type: 0051 QMIWDS_SET_AUTO_CONNECT_RESP
Length: 0007
{02, 0004, 01 00 1a 00 }
[12-05_11:39:26:405] 01 0c 00 00 0b 00 00 06 00 2f 00 00 00
[12-05_11:39:26:405] TransactionId: 0006
Type: 002f QMIUIM_GET_CARD_STATUS_REQ
Length: 0000
[12-05_11:39:26:436] 01 80 00 80 0b 02 02 06 00 2f 00 74 00 02 04 00 00 00 00 00 18 02 00 01 00 17 23 00 01 0a 98 33 10 11 84 98 67 49 43 03 15 3b 9e 96 80 1f c7 80 31 e0 73 fe 21 1b 66 d0 02 17 60 13 00 66 00 16 05 00 01 00 00 00 00 15 02 00 01 00 11 02 00 01 00 10 2d 00 00 00 ff ff ff ff ff ff 01 01 00 00 00 00 01 02 07 02 0b 00 00 10 a0 00 00 00 87 10 02 ff 33 ff 01 89 00 00 01 00 00 02 03 0a 01 03 0a
[12-05_11:39:26:437] TransactionId: 0006
Type: 002f QMIUIM_GET_CARD_STATUS_RESP
Length: 0074
{18, 0002, 01 00 }
{17, 0023, 01 0a 98 33 10 11 84 98 67 49 43 03 15 3b 9e 96 80 1f c7 80 31 e0 73 fe 21 1b 66 d0 02 17 60 13 00 66 00 }
{16, 0005, 01 00 00 00 00 }
{15, 0002, 01 00 }
{11, 0002, 01 00 }
{10, 002d, 00 00 ff ff ff ff ff ff 01 01 00 00 00 00 01 02 07 02 0b 00 00 10 a0 00 00 00 87 10 02 ff 33 ff 01 89 00 00 01 00 00 02 03 0a 01 03 0a }
[12-05_11:39:26:437] requestGetSIMStatus SIMStatus: SIM_READY
[12-05_11:39:26:437] 01 0c 00 00 03 00 00 07 00 4d 00 00 00
[12-05_11:39:26:437] TransactionId: 0007
Type: 004d QMINAS_GET_SYS_INFO_REQ
Length: 0000
[12-05_11:39:26:469] 01 90 00 80 03 03 02 07 00 4d 00 84 00 02 04 00 00 00 00 00 14 03 00 02 02 00 19 1d 00 01 03 01 03 01 00 01 00 00 ff ff 01 06 16 5d 01 00 00 00 01 32 30 38 30 31 ff 01 40 9a 21 01 00 00 27 04 00 01 00 00 00 29 01 00 01 2a 04 00 00 00 00 00 2f 04 00 00 00 00 00 31 04 00 00 00 00 00 38 04 00 03 00 00 00 39 04 00 01 00 00 00 3e 04 00 00 00 00 00 44 04 00 03 00 00 00 4a 03 00 00 00 00 5b 04 00 02 00 00 00 5f 07 00 08 32 30 38 30 31 ff
[12-05_11:39:26:469] TransactionId: 0007
Type: 004d QMINAS_GET_SYS_INFO_RESP
Length: 0084
{14, 0003, 02 02 00 }
{19, 001d, 01 03 01 03 01 00 01 00 00 ff ff 01 06 16 5d 01 00 00 00 01 32 30 38 30 31 ff 01 40 9a }
{21, 0001, 00 }
{27, 0004, 01 00 00 00 }
{29, 0001, 01 }
{2a, 0004, 00 00 00 00 }
{2f, 0004, 00 00 00 00 }
{31, 0004, 00 00 00 00 }
{38, 0004, 03 00 00 00 }
{39, 0004, 01 00 00 00 }
{3e, 0004, 00 00 00 00 }
{44, 0004, 03 00 00 00 }
{4a, 0003, 00 00 00 }
{5b, 0004, 02 00 00 00 }
{5f, 0007, 08 32 30 38 30 31 ff }
[12-05_11:39:26:470] requestRegistrationState2 MCC: 208, MNC: 1, PS: Attached, DataCap: LTE
[12-05_11:39:26:470] 01 0c 00 00 01 00 00 08 00 22 00 00 00
[12-05_11:39:26:470] TransactionId: 0008
Type: 0022 QMIWDS_GET_PKT_SRVC_STATUS_REQ
Length: 0000
[12-05_11:39:26:500] 01 17 00 80 01 09 02 08 00 22 00 0b 00 02 04 00 00 00 00 00 01 01 00 01
[12-05_11:39:26:500] TransactionId: 0008
Type: 0022 QMIWDS_GET_PKT_SRVC_STATUS_RESP
Length: 000b
{01, 0001, 01 }
[12-05_11:39:26:501] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[12-05_11:39:26:501] ip addr flush dev wwan2
[12-05_11:39:26:512] ip link set dev wwan2 down
[12-05_11:39:26:524] 01 14 00 00 01 00 00 09 00 20 00 08 00 30 01 00 01 19 01 00 04
[12-05_11:39:26:524] TransactionId: 0009
Type: 0020 QMIWDS_START_NETWORK_INTERFACE_REQ
Length: 0008
{30, 0001, 01 }
{19, 0001, 04 }
[12-05_11:39:26:565] 01 1a 00 80 01 09 02 09 00 20 00 0e 00 02 04 00 00 00 00 00 01 04 00 d0 1a 86 e0
[12-05_11:39:26:565] TransactionId: 0009
Type: 0020 QMIWDS_START_NETWORK_INTERFACE_RESP
Length: 000e
{01, 0004, d0 1a 86 e0 }
[12-05_11:39:26:565] requestSetupDataCall WdsConnectionIPv4Handle: 0xe0861ad0
[12-05_11:39:26:565] 01 13 00 00 01 00 00 0a 00 2d 00 07 00 10 04 00 10 6b 00 00
[12-05_11:39:26:565] TransactionId: 000a
Type: 002d QMIWDS_GET_RUNTIME_SETTINGS_REQ
Length: 0007
{10, 0004, 10 6b 00 00 }
[12-05_11:39:26:596] 01 22 00 80 01 09 04 01 00 22 00 16 00 01 02 00 02 00 12 01 00 04 13 02 00 81 88 14 01 00 00 15 01 00 00
[12-05_11:39:26:597] TransactionId: 0001
Type: 0022 QMIWDS_GET_PKT_SRVC_STATUS_IND
Length: 0016
{01, 0002, 02 00 }
{12, 0001, 04 }
{13, 0002, 81 88 }
{14, 0001, 00 }
{15, 0001, 00 }
[12-05_11:39:26:628] 01 3e 00 80 01 09 02 0a 00 2d 00 32 00 02 04 00 00 00 00 00 15 04 00 6e 0a a8 c0 1e 04 00 20 b6 00 0a 20 04 00 21 b6 00 0a 21 04 00 c0 ff ff ff 23 01 00 00 29 04 00 dc 05 00 00 2a 01 00 00
[12-05_11:39:26:629] TransactionId: 000a
Type: 002d QMIWDS_GET_RUNTIME_SETTINGS_RESP
Length: 0032
{15, 0004, 6e 0a a8 c0 }
{1e, 0004, 20 b6 00 0a }
{20, 0004, 21 b6 00 0a }
{21, 0004, c0 ff ff ff }
{23, 0001, 00 }
{29, 0004, dc 05 00 00 }
{2a, 0001, 00 }
[12-05_11:39:26:629] 01 0c 00 00 01 00 00 0b 00 22 00 00 00
[12-05_11:39:26:629] TransactionId: 000b
Length: 0000
[12-05_11:39:26:660] 01 17 00 80 01 09 02 0b 00 22 00 0b 00 02 04 00 00 00 00 00 01 01 00 02
[12-05_11:39:26:660] TransactionId: 000b
Length: 000b
{01, 0001, 02 }
[12-05_11:39:26:661] requestQueryDataCall IPv4ConnectionStatus: CONNECTED
[12-05_11:39:26:661] 01 13 00 00 01 00 00 0c 00 2d 00 07 00 10 04 00 10 6b 00 00
[12-05_11:39:26:661] TransactionId: 000c
Length: 0007
[12-05_11:39:26:692] 01 3e 00 80 01 09 02 0c 00 2d 00 32 00 02 04 00 00 00 00 00 15 04 00 6e 0a a8 c0 1e 04 00 20 b6 00 0a 20 04 00 21 b6 00 0a 21 04 00 c0 ff ff ff 23 01 00 00 29 04 00 dc 05 00 00 2a 01 00 00
[12-05_11:39:26:693] TransactionId: 000c
Length: 0032
{23, 0001, 00 }
{2a, 0001, 00 }
[12-05_11:39:26:693] localIP: 10.0.182.32 VS remoteIP: 10.0.182.32
[12-05_11:39:26:693] ip link set dev wwan2 up
[12-05_11:39:26:705] ip -4 address flush dev wwan2
[12-05_11:39:26:716] ip -4 address add 10.0.182.32/26 dev wwan2
[12-05_11:39:26:728] ip -4 route add default via 10.0.182.33 dev wwan2
debug file
Dec 5 11:39:21 wwan2 kernel: pnp 00:03: [dma 0 disabled]
Dec 5 11:39:21 wwan2 kernel: Monitor-Mwait will be used to enter C-1 state
Dec 5 11:39:21 wwan2 kernel: Monitor-Mwait will be used to enter C-2 state
Dec 5 11:39:21 wwan2 kernel: ahci 0000:00:13.0: version 3.0
Dec 5 11:39:21 wwan2 kernel: sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
Dec 5 11:39:21 wwan2 kernel: with arguments:
Dec 5 11:39:21 wwan2 kernel: /sbin/init
Dec 5 11:39:21 wwan2 kernel: with environment:
Dec 5 11:39:21 wwan2 kernel: HOME=/
Dec 5 11:39:21 wwan2 kernel: TERM=linux
Dec 5 11:39:21 wwan2 kernel: BOOT_IMAGE=/boot/vmlinuz
system message file
Dec 5 11:39:21 wwan2 kernel: usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
Dec 5 11:39:21 wwan2 kernel: usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 5 11:39:21 wwan2 kernel: usb usb1: Product: xHCI Host Controller
Dec 5 11:39:21 wwan2 kernel: usb usb1: Manufacturer: Linux 6.6.40 xhci-hcd
Dec 5 11:39:21 wwan2 kernel: usb usb1: SerialNumber: 0000:00:14.0
Dec 5 11:39:21 wwan2 kernel: hub 1-0:1.0: USB hub found
Dec 5 11:39:21 wwan2 kernel: hub 1-0:1.0: 6 ports detected
Dec 5 11:39:21 wwan2 kernel: usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
Dec 5 11:39:21 wwan2 kernel: usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
Dec 5 11:39:21 wwan2 kernel: usb usb2: Product: xHCI Host Controller
Dec 5 11:39:21 wwan2 kernel: usb usb2: Manufacturer: Linux 6.6.40 xhci-hcd
Dec 5 11:39:21 wwan2 kernel: usb usb2: SerialNumber: 0000:00:14.0
Dec 5 11:39:21 wwan2 kernel: hub 2-0:1.0: USB hub found
Dec 5 11:39:21 wwan2 kernel: hub 2-0:1.0: 1 port detected
Dec 5 11:39:21 wwan2 kernel: usb 1-3: new high-speed USB device number 2 using xhci_hcd
Dec 5 11:39:21 wwan2 kernel: usb 1-3: New USB device found, idVendor=1a40, idProduct=0101, bcdDevice= 1.11
Dec 5 11:39:21 wwan2 kernel: usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
Dec 5 11:39:21 wwan2 kernel: usb 1-3: Product: USB 2.0 Hub
Dec 5 11:39:21 wwan2 kernel: hub 1-3:1.0: USB hub found
Dec 5 11:39:21 wwan2 kernel: hub 1-3:1.0: 4 ports detected
Dec 5 11:39:21 wwan2 kernel: usb 1-4: new full-speed USB device number 3 using xhci_hcd
Dec 5 11:39:21 wwan2 kernel: usb 1-4: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
Dec 5 11:39:21 wwan2 kernel: usb 1-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Dec 5 11:39:21 wwan2 kernel: usb 1-4: Product: USB Serial
Dec 5 11:39:21 wwan2 kernel: usb 1-3.1: new full-speed USB device number 4 using xhci_hcd
Dec 5 11:39:21 wwan2 kernel: usb 1-3.1: New USB device found, idVendor=1a86, idProduct=7523, bcdDevice= 2.64
Dec 5 11:39:21 wwan2 kernel: usb 1-3.1: New USB device strings: Mfr=0, Product=2, SerialNumber=0
Dec 5 11:39:21 wwan2 kernel: usb 1-3.1: Product: USB Serial
Dec 5 11:39:21 wwan2 kernel: usb 1-3.2: new high-speed USB device number 5 using xhci_hcd
Dec 5 11:39:21 wwan2 kernel: usb 1-3.2: New USB device found, idVendor=2c7c, idProduct=0316, bcdDevice= 5.15
Dec 5 11:39:21 wwan2 kernel: usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Dec 5 11:39:21 wwan2 kernel: usb 1-3.2: Product: RG255C-GL
Dec 5 11:39:21 wwan2 kernel: usb 1-3.2: Manufacturer: Quectel
Dec 5 11:39:21 wwan2 kernel: usb 1-3.2: SerialNumber: ad1ad481
Dec 5 11:39:21 wwan2 kernel: ata1: SATA link down (SStatus 0 SControl 300)
Dec 5 11:39:21 wwan2 kernel: ata1: SATA link down (SStatus 0 SControl 310)
Dec 5 11:39:21 wwan2 last message repeated 6 times
Dec 5 11:39:21 wwan2 kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Dec 5 11:39:21 wwan2 kernel: ata2.00: configured for UDMA/133
Dec 5 11:39:21 wwan2 kernel: FAT-fs (sda3): Can’t find a valid FAT filesystem
Dec 5 11:39:21 wwan2 kernel: 8021q: adding VLAN 0 to HW filter on device eth0
Dec 5 11:39:21 wwan2 kernel: igb 0000:03:00.0 eth0: igb: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Dec 5 11:39:21 wwan2 kernel: 8021q: adding VLAN 0 to HW filter on device eth1
Dec 5 11:39:21 wwan2 kernel: 8021q: adding VLAN 0 to HW filter on device eth2
Dec 5 11:39:21 wwan2 kernel: igb 0000:04:00.0 eth1: igb: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Dec 5 11:39:21 wwan2 kernel: qmi_wwan_q 1-3.2:1.3: cdc-wdm0: USB WDM device
Dec 5 11:39:21 wwan2 kernel: wwan wwan2: port wwan2qmi0 attached
Dec 5 11:39:21 wwan2 kernel: qmi_wwan_q 1-3.2:1.3: Quectel RG255C-GL work on RawIP mode
Dec 5 11:39:21 wwan2 kernel: qmi_wwan_q 1-3.2:1.3: rx_urb_size = 16384
Dec 5 11:39:21 wwan2 kernel: qmi_wwan_q 1-3.2:1.3 wwan2: register ‘qmi_wwan_q’ at usb-0000:00:14.0-3.2, WWAN/QMI Raw IP device, 06:75:15:29:ab:c3
Dec 5 11:39:21 wwan2 kernel: usbcore: registered new interface driver qmi_wwan_q
Dec 5 11:39:26 wwan2 kernel: net wwan2: ul_data_aggregation_max_datagrams=11, ul_data_aggregation_max_size=8192, dl_minimum_padding=0
Dec 5 11:39:26 wwan2 kernel: net wwan2: link_state 0x0 → 0x1
Dec 5 11:39:35 wwan2 kernel: xt_ndpi v1.2 ndpi 4.9.0 IPv6=YES debug_message=no
Dec 5 11:39:35 wwan2 kernel: BT: hash_size 0k, hash_expiation 0 sec, log_size 128kb
Dec 5 11:39:35 wwan2 kernel: sizeof hash_ip4p_node=44 flow_struct=968 packet_struct=1424
Dec 5 11:39:35 wwan2 kernel: flow_tcp_struct=112 flow_udp_struct=104 int_one_line_struct=16
Dec 5 11:39:35 wwan2 kernel: ndpi_ip_addr_t=16 ndpi_protocol=6 nf_ct_ext_ndpi=176
Dec 5 11:39:35 wwan2 kernel: flow_info=112 spinlock_t=4 NF_LABEL_ID 7
Dec 5 11:39:35 wwan2 kernel: xt_ndpi: MAX_PROTOCOLS 512 LAST_PROTOCOL 353
Dec 5 11:39:35 wwan2 kernel: xt_ndpi: flow accounting OFF
Dec 5 11:39:36 wwan2 root: Shorewall started
Dec 5 11:39:36 wwan2 named[3469]: starting BIND 9.11.37 (Extended Support Version) id:796133c
I need the complete dmesg log then I can know why it is wwan2 but not wwan0.
Normally it should be wwan0 if there is wwan0 before.
I’ve send it by email, too big
I have reduced the size
[ 0.290830] pci 0000:02:01.0: bridge window [io 0xe000-0xefff]
[ 0.290891] pci 0000:02:01.0: bridge window [mem 0xd0b00000-0xd0bfffff]
[ 0.290956] pci 0000:02:03.0: PCI bridge to [bus 04]
[ 0.291011] pci 0000:02:03.0: bridge window [io 0xd000-0xdfff]
[ 0.291071] pci 0000:02:03.0: bridge window [mem 0xd0a00000-0xd0afffff]
[ 0.291135] pci 0000:02:05.0: PCI bridge to [bus 05]
[ 0.291191] pci 0000:02:05.0: bridge window [io 0xc000-0xcfff]
[ 0.291255] pci 0000:02:05.0: bridge window [mem 0xd0900000-0xd09fffff]
[ 0.291320] pci 0000:02:07.0: PCI bridge to [bus 06]
[ 0.291385] pci 0000:01:00.0: PCI bridge to [bus 02-06]
[ 0.291441] pci 0000:01:00.0: bridge window [io 0xc000-0xefff]
[ 0.291500] pci 0000:01:00.0: bridge window [mem 0xd0900000-0xd0bfffff]
[ 0.291564] pci 0000:00:1c.0: PCI bridge to [bus 01-06]
[ 0.291619] pci 0000:00:1c.0: bridge window [io 0xc000-0xefff]
[ 0.291677] pci 0000:00:1c.0: bridge window [mem 0xd0900000-0xd0bfffff]
[ 0.291739] pci 0000:00:1c.1: PCI bridge to [bus 07]
[ 0.291794] pci 0000:00:1c.1: bridge window [io 0x1000-0x1fff]
[ 0.291856] pci 0000:00:1c.2: PCI bridge to [bus 08]
[ 0.291911] pci 0000:00:1c.2: bridge window [io 0x2000-0x2fff]
[ 0.291973] pci 0000:00:1c.3: PCI bridge to [bus 09]
[ 0.292028] pci 0000:00:1c.3: bridge window [io 0x3000-0x3fff]
[ 0.292086] pci 0000:00:1c.3: bridge window [mem 0xd0400000-0xd06fffff]
[ 0.292148] pci_bus 0000:00: resource 4 [io 0x0070-0x0077]
[ 0.292204] pci_bus 0000:00: resource 5 [io 0x0000-0x006f window]
[ 0.292265] pci_bus 0000:00: resource 6 [io 0x0078-0x0cf7 window]
[ 0.292323] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 0.292379] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000fffff window]
[ 0.292437] pci_bus 0000:00: resource 9 [mem 0xc0000000-0xd0c13fff window]
[ 0.292495] pci_bus 0000:01: resource 0 [io 0xc000-0xefff]
[ 0.292550] pci_bus 0000:01: resource 1 [mem 0xd0900000-0xd0bfffff]
[ 0.292607] pci_bus 0000:02: resource 0 [io 0xc000-0xefff]
[ 0.292662] pci_bus 0000:02: resource 1 [mem 0xd0900000-0xd0bfffff]
[ 0.292718] pci_bus 0000:03: resource 0 [io 0xe000-0xefff]
[ 0.292774] pci_bus 0000:03: resource 1 [mem 0xd0b00000-0xd0bfffff]
[ 0.292830] pci_bus 0000:04: resource 0 [io 0xd000-0xdfff]
[ 0.292886] pci_bus 0000:04: resource 1 [mem 0xd0a00000-0xd0afffff]
[ 0.292942] pci_bus 0000:05: resource 0 [io 0xc000-0xcfff]
[ 0.292997] pci_bus 0000:05: resource 1 [mem 0xd0900000-0xd09fffff]
[ 0.293054] pci_bus 0000:07: resource 0 [io 0x1000-0x1fff]
[ 0.293110] pci_bus 0000:08: resource 0 [io 0x2000-0x2fff]
[ 0.293165] pci_bus 0000:09: resource 0 [io 0x3000-0x3fff]
[ 0.293220] pci_bus 0000:09: resource 1 [mem 0xd0400000-0xd06fffff]
[ 0.293802] PCI: CLS 64 bytes, default 64
[ 0.293871] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.293928] software IO TLB: mapped [mem 0x00000000b5c73000-0x00000000b9c7300
[ 0.294154] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x3741594d
[ 0.294252] clocksource: Switched to clocksource tsc
[ 0.294796] CPU feature ‘AVX registers’ is not supported.
[ 0.294873] CPU feature ‘AVX registers’ is not supported.
[ 0.294927] AVX2 instructions are not detected.
[ 0.294988] AVX or AES-NI instructions are not detected.
[ 0.295041] AVX2 or AES-NI instructions are not detected.
[ 0.295105] CPU feature ‘AVX registers’ is not supported.
[ 0.295160] CPU feature ‘AVX registers’ is not supported.
[ 0.295866] Initialise system trusted keyrings
[ 0.296000] workingset: timestamp_bits=62 max_order=20 bucket_order=0
[ 0.296275] DLM installed
[ 0.296968] Key type cifs.spnego registered
[ 0.297034] Key type cifs.idmap registered
[ 0.297095] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.297157] fuse: init (API version 7.39)
[ 0.317905] jitterentropy: Initialization failed with host not compliant with
[ 0.317978] xor: measuring software checksum speed
[ 0.319315] prefetch64-sse : 7717 MB/sec
[ 0.320812] generic_sse : 6837 MB/sec
[ 0.320866] xor: using function: prefetch64-sse (7717 MB/sec)
[ 0.320926] Key type asymmetric registered
[ 0.320978] Asymmetric key parser ‘x509’ registered
[ 0.321059] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2
[ 0.321120] io scheduler mq-deadline registered
[ 0.321173] io scheduler kyber registered
[ 0.321243] io scheduler bfq registered
[ 0.323744] hv_vmbus: registering driver hyperv_fb
[ 0.323852] IPMI message handler: version 39.2
[ 0.323923] ipmi device interface
[ 0.324060] ipmi_si: IPMI System Interface driver
[ 0.324188] ipmi_si: Unable to find any System Interface(s)
[ 0.324260] IPMI Watchdog: driver initialized
[ 0.324314] IPMI poweroff: Copyright (C) 2004 MontaVista Software - IPMI Powe
[ 0.324634] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:0
[ 0.324757] ACPI: button: Sleep Button [SLPB]
[ 0.324896] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/inp
[ 0.325059] ACPI: button: Power Button [PWRF]
[ 0.325882] Monitor-Mwait will be used to enter C-1 state
[ 0.325911] Monitor-Mwait will be used to enter C-2 state
[ 0.325928] ACPI: _PR_.CPU0: Found 3 idle states
[ 0.327899] ACPI: _PR_.CPU1: Found 3 idle states
[ 0.328572] ACPI: _PR_.CPU2: Found 3 idle states
[ 0.329238] ACPI: _PR_.CPU3: Found 3 idle states
[ 0.342980] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.343274] 00:03: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 1655
[ 0.344254] Linux agpgart interface v0.103
[ 0.344440] ACPI: bus type drm_connector registered
[ 0.350174] brd: module loaded
[ 0.352519] loop: module loaded
[ 0.352658] Guest personality initialized and is inactive
[ 0.353301] VMCI host device registered (name=vmci, major=10, minor=123)
[ 0.353360] Initialized host personality
[ 0.353489] Loading iSCSI transport class v2.0-870.
[ 0.355222] isci: Intel(R) C600 SAS Controller Driver - version 1.2.0
[ 0.355416] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 200
[ 0.355521] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[ 0.355605] megasas: 07.725.01.00-rc1
[ 0.355703] mpt3sas version 43.100.00.00 loaded
[ 0.355847] ipr: IBM Power RAID SCSI Device Driver version: 2.6.4 (March 14,
[ 0.355937] stex: Promise SuperTrak EX Driver version: 6.02.0000.01
[ 0.356047] VMware PVSCSI driver - version 1.0.7.0-k
[ 0.356128] hv_vmbus: registering driver hv_storvsc
[ 0.356185] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[ 0.356386] ahci 0000:00:13.0: version 3.0
[ 0.356584] ahci 0000:00:13.0: controller can’t do DEVSLP, turning off
[ 0.356772] ahci 0000:00:13.0: AHCI 0001.0300 32 slots 2 ports 3 Gbps 0x3 imp
[ 0.356837] ahci 0000:00:13.0: flags: 64bit ncq pm led clo pio slum part deso
[ 0.357483] scsi host0: ahci
[ 0.357890] scsi host1: ahci
[ 0.358046] ata1: SATA max UDMA/133 abar m2048@0xd0c13000 port 0xd0c13100 irq
[ 0.358110] ata2: SATA max UDMA/133 abar m2048@0xd0c13000 port 0xd0c13180 irq
[ 0.361804] eql: Equalizer2002: Simon Janes (simon@ncm.com) and David S. Mill
[ 0.362362] tun: Universal TUN/TAP device driver, 1.6
[ 0.362489] PPP generic driver version 2.4.2
[ 0.363008] wwan wwan0: port wwan0at0 attached
[ 0.363118] wwan wwan0: port wwan0at1 attached
[ 0.363537] wwan wwan1: port wwan1at0 attached
[ 0.363651] wwan wwan1: port wwan1at1 attached
[ 0.363715] VMware vmxnet3 virtual NIC driver - version 1.7.0.0-k-NAPI
[ 0.363842] usbcore: registered new interface driver ax88179_178a
[ 0.363917] usbcore: registered new interface driver cdc_ether
[ 0.363991] usbcore: registered new interface driver cdc_eem
[ 0.364065] usbcore: registered new interface driver cdc_subset
[ 0.364140] usbcore: registered new interface driver cdc_ncm
[ 0.364218] usbcore: registered new interface driver qmi_wwan
[ 0.364307] usbcore: registered new interface driver cdc_mbim
[ 0.364382] usbcore: registered new interface driver r8153_ecm
[ 0.364444] hv_vmbus: registering driver hv_netvsc
[ 0.364502] Fusion MPT base driver 3.04.20
[ 0.364555] Copyright (c) 1999-2008 LSI Corporation
[ 0.364613] Fusion MPT SPI Host driver 3.04.20
[ 0.364695] Fusion MPT FC Host driver 3.04.20
[ 0.364779] Fusion MPT SAS Host driver 3.04.20
[ 0.364862] Fusion MPT misc device (ioctl) driver 3.04.20
[ 0.364952] mptctl: Registered with Fusion MPT base driver
[ 0.365009] mptctl: /dev/mptctl @ (major,minor=10,220)
[ 0.365065] Fusion MPT LAN driver 3.04.20
[ 0.365376] usbcore: registered new interface driver cdc_acm
[ 0.365435] cdc_acm: USB Abstract Control Model driver for USB modems and ISD
[ 0.365516] usbcore: registered new interface driver cdc_wdm
[ 0.365591] usbcore: registered new interface driver usb-storage
[ 0.365667] usbcore: registered new interface driver ums-alauda
[ 0.365738] usbcore: registered new interface driver ums-datafab
[ 0.365814] usbcore: registered new interface driver ums-freecom
[ 0.365887] usbcore: registered new interface driver ums-isd200
[ 0.365960] usbcore: registered new interface driver ums-jumpshot
[ 0.366032] usbcore: registered new interface driver ums-sddr09
[ 0.366106] usbcore: registered new interface driver ums-sddr55
[ 0.366179] usbcore: registered new interface driver ums-usbat
[ 0.366303] usbcore: registered new interface driver usbserial_generic
[ 0.366378] usbserial: USB Serial support registered for generic
[ 0.366452] usbcore: registered new interface driver usb_serial_simple
[ 0.366523] usbserial: USB Serial support registered for carelink
[ 0.366593] usbserial: USB Serial support registered for flashloader
[ 0.366665] usbserial: USB Serial support registered for funsoft
[ 0.366735] usbserial: USB Serial support registered for google
[ 0.366805] usbserial: USB Serial support registered for hp4x
[ 0.366877] usbserial: USB Serial support registered for kaufmann
[ 0.366949] usbserial: USB Serial support registered for libtransistor
[ 0.367021] usbserial: USB Serial support registered for moto_modem
[ 0.367092] usbserial: USB Serial support registered for motorola_tetra
[ 0.367163] usbserial: USB Serial support registered for nokia
[ 0.367255] usbserial: USB Serial support registered for novatel_gps
[ 0.367328] usbserial: USB Serial support registered for siemens_mpi
[ 0.367399] usbserial: USB Serial support registered for suunto
[ 0.367470] usbserial: USB Serial support registered for vivopay
[ 0.367544] usbserial: USB Serial support registered for zio
[ 0.367687] i8042: PNP: No PS/2 controller found.
[ 0.367745] hv_vmbus: registering driver hyperv_keyboard
[ 0.367881] mousedev: PS/2 mouse device common for all mice
[ 0.368050] input: PC Speaker as /devices/platform/pcspkr/input/input2
[ 0.368164] rtc_cmos 00:00: RTC can wake from S4
[ 0.368562] rtc_cmos 00:00: registered as rtc0
[ 0.368647] rtc_cmos 00:00: setting system clock to 2024-12-05T11:55:42 UTC (
[ 0.368787] rtc_cmos 00:00: alarms up to one month, y3k, 242 bytes nvram
[ 0.368918] IR JVC protocol handler initialized
[ 0.368974] IR MCE Keyboard/mouse protocol handler initialized
[ 0.369028] IR NEC protocol handler initialized
[ 0.369081] IR RC5(x/sz) protocol handler initialized
[ 0.369134] IR RC6 protocol handler initialized
[ 0.369185] IR SANYO protocol handler initialized
[ 0.369253] IR Sharp protocol handler initialized
[ 0.369306] IR Sony protocol handler initialized
[ 0.369358] IR XMP protocol handler initialized
[ 0.369410] Driver for 1-wire Dallas network protocol.
[ 0.369863] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised: dm-d
[ 0.370086] device-mapper: multipath round-robin: version 1.2.0 loaded
[ 0.370161] intel_pstate: Intel P-state driver initializing
[ 0.370457] sdhci: Secure Digital Host Controller Interface driver
[ 0.370519] sdhci: Copyright(c) Pierre Ossman
[ 0.370743] sdhci-pci 0000:00:17.0: SDHCI controller found [8086:0f50] (rev 1
[ 0.370761] wbsd: Winbond W83L51xD SD/MMC card interface driver
[ 0.370770] wbsd: Copyright(c) Pierre Ossman
[ 0.373012] mmc0: SDHCI controller on PCI [0000:00:17.0] using ADMA
[ 0.373693] hv_vmbus: registering driver hid_hyperv
[ 0.374543] usbcore: registered new interface driver usbhid
[ 0.374641] usbhid: USB HID core driver
[ 0.375658] hv_vmbus: registering driver hv_balloon
[ 0.376710] NET: Registered PF_LLC protocol family
[ 0.376830] GACT probability on
[ 0.376934] Mirror/redirect action on
[ 0.377777] netem: version 1.3
[ 0.377895] u32 classifier
[ 0.377971] Performance counters on
[ 0.378046] input device check on
[ 0.378118] Actions configured
[ 0.379982] xt_time: kernel timezone is -0000
[ 0.380466] ipip: IPv4 and MPLS over IPv4 tunneling driver
[ 0.381281] gre: GRE over IPv4 demultiplexor driver
[ 0.381373] ip_gre: GRE over IPv4 tunneling driver
[ 0.383570] IPv4 over IPsec tunneling driver
[ 0.384479] Initializing XFRM netlink socket
[ 0.384612] NET: Registered PF_PACKET protocol family
[ 0.384715] NET: Registered PF_KEY protocol family
[ 0.384865] Bridge firewalling registered
[ 0.385110] l2tp_core: L2TP core driver, V2.0
[ 0.385199] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
[ 0.385309] l2tp_netlink: L2TP netlink interface
[ 0.385462] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
[ 0.385549] 8021q: 802.1Q VLAN Support v1.8
[ 0.393852] DCCP: Activated CCID 2 (TCP-like)
[ 0.394028] DCCP is deprecated and scheduled to be removed in 2025, please co
[ 0.394180] sctp: Hash tables configured (bind 256/256)
[ 0.394733] NET: Registered PF_RDS protocol family
[ 0.394960] Registered RDS/tcp transport
[ 0.395063] NET: Registered PF_IEEE802154 protocol family
[ 0.395170] Key type dns_resolver registered
[ 0.397857] microcode: Microcode Update Driver: v2.2.
[ 0.397895] IPI shorthand broadcast: enabled
[ 0.398087] SSE version of gcm_enc/dec engaged.
[ 0.431859] sched_clock: Marking stable (422196274, 9035818)->(474688814, -43
[ 0.432241] Loading compiled-in X.509 certificates
[ 0.453492] clk: Disabling unused clocks
[ 0.453618] ALSA device list:
[ 0.453695] No soundcards found.
[ 0.583254] mmc0: Failed to initialize a non-removable card
[ 0.668261] ata1: SATA link down (SStatus 0 SControl 300)
[ 0.668476] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 0.668952] ata2.00: supports DRM functions and may not be fully accessible
[ 0.669050] ata2.00: ATA-11: KINGSTON SUV500MS120G, 003056RI, max UDMA/133
[ 0.669279] ata2.00: 234441648 sectors, multi 1: LBA48 NCQ (depth 32), AA
[ 0.671557] ata2.00: supports DRM functions and may not be fully accessible
[ 0.673495] ata2.00: configured for UDMA/133
[ 3.422307] floppy0: no floppy controllers found
[ 3.423292] scsi 1:0:0:0: Direct-Access ATA KINGSTON SUV500M 56RI PQ
[ 3.425891] sd 1:0:0:0: Attached scsi generic sg0 type 0
[ 3.426045] sd 1:0:0:0: [sda] 234441648 512-byte logical blocks: (120 GB/112
[ 3.426157] sd 1:0:0:0: [sda] 4096-byte physical blocks
[ 3.426463] sd 1:0:0:0: [sda] Write Protect is off
[ 3.426564] sd 1:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 3.426742] sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, does
[ 3.427091] sd 1:0:0:0: [sda] Preferred minimum I/O size 4096 bytes
[ 3.429539] sda: sda1 sda2 sda3 sda4
[ 3.430339] sd 1:0:0:0: [sda] Attached SCSI disk
[ 3.430560] md: Waiting for all devices to be available before autodetect
[ 3.430659] md: If you don’t use raid, use raid=noautodetect
[ 3.430745] md: Autodetecting RAID arrays.
[ 3.430821] md: autorun …
[ 3.430893] md: … autorun DONE.
[ 3.432005] REISERFS warning: read_super_block: reiserfs filesystem is depre
[ 3.432143] REISERFS (device sda2): found reiserfs format “3.6” with standard
[ 3.432286] REISERFS (device sda2): using ordered data mode
[ 3.432375] reiserfs: using flush barriers
[ 3.432866] REISERFS (device sda2): journal params: device sda2, size 8192, j
[ 3.434336] REISERFS (device sda2): checking transaction log (sda2)
[ 3.435582] REISERFS (device sda2): replayed 1 transactions in 0 seconds
[ 3.441203] REISERFS (device sda2): Using r5 hash to sort names
[ 3.442125] VFS: Mounted root (reiserfs filesystem) readonly on device 8:2.
[ 3.446275] Freeing unused kernel image (initmem) memory: 1684K
[ 3.446554] Write protecting the kernel read-only data: 22528k
[ 3.449616] Freeing unused kernel image (rodata/data gap) memory: 1984K
[ 3.449929] rodata_test: all tests were successful
[ 3.450054] Run /sbin/init as init process
[ 3.450136] with arguments:
[ 3.450143] /sbin/init
[ 3.450151] with environment:
[ 3.450157] HOME=/
[ 3.450164] TERM=linux
[ 3.450170] BOOT_IMAGE=/boot/vmlinuz
[ 3.635533] reiserfs: enabling write barrier flush mode
[ 5.091600] pps_core: LinuxPPS API ver. 1 registered
[ 5.091702] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome
[ 5.096014] PTP clock support registered
[ 5.115480] igb: Intel(R) Gigabit Ethernet Network Driver
[ 5.115585] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 5.144930] pps pps0: new PPS source ptp0
[ 5.145269] igb 0000:03:00.0: added PHC on eth0
[ 5.145388] igb 0000:03:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 5.145479] igb 0000:03:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 1c:ae:3e:e0:18:ab
[ 5.145576] igb 0000:03:00.0: eth0: PBA No: FFFFFF-0FF
[ 5.145660] igb 0000:03:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx que
[ 5.176219] pps pps1: new PPS source ptp1
[ 5.177841] igb 0000:04:00.0: added PHC on eth1
[ 5.177974] igb 0000:04:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 5.178065] igb 0000:04:00.0: eth1: (PCIe:2.5Gb/s:Width x1) 1c:ae:3e:e0:18:ac
[ 5.178163] igb 0000:04:00.0: eth1: PBA No: FFFFFF-0FF
[ 5.178283] igb 0000:04:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx que
[ 5.209984] pps pps2: new PPS source ptp2
[ 5.210407] igb 0000:05:00.0: added PHC on eth2
[ 5.210525] igb 0000:05:00.0: Intel(R) Gigabit Ethernet Network Connection
[ 5.210617] igb 0000:05:00.0: eth2: (PCIe:2.5Gb/s:Width x1) 1c:ae:3e:e0:18:ad
[ 5.210728] igb 0000:05:00.0: eth2: PBA No: FFFFFF-0FF
[ 5.210824] igb 0000:05:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx que
[ 5.286679] e1000e: Intel(R) PRO/1000 Network Driver
[ 5.286778] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 5.316299] e1000: Intel(R) PRO/1000 Network Driver
[ 5.316401] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 5.411331] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 5.483631] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver
[ 5.483737] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 5.574529] i40e: Intel(R) Ethernet Connection XL710 Network Driver
[ 5.574637] i40e: Copyright (c) 2013 - 2019 Intel Corporation.
[ 5.623154] cfg80211: Loading compiled-in X.509 certificates for regulatory d
[ 5.642678] Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600
[ 5.645078] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 5.651936] cfg80211: loaded regulatory.db is malformed or signature is missi
[ 5.806304] ath10k_pci 0000:09:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 r
[ 5.897882] Intel(R) Wireless WiFi driver for Linux
[ 5.912620] PPP MPPE Compression module registered
[ 5.949480] PPP Deflate Compression module registered
[ 5.961156] PPP BSD Compression module registered
[ 5.973029] NET: Registered PF_PPPOX protocol family
[ 9.122244] REISERFS warning: read_super_block: reiserfs filesystem is depre
[ 9.122385] REISERFS (device sda4): found reiserfs format “3.6” with standard
[ 9.122503] REISERFS (device sda4): using ordered data mode
[ 9.122589] reiserfs: using flush barriers
[ 9.123101] REISERFS (device sda4): journal params: device sda4, size 8192, j
[ 9.124539] REISERFS (device sda4): checking transaction log (sda4)
[ 9.129968] REISERFS (device sda4): Using r5 hash to sort names
[ 9.471970] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 9.472335] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus numbe
[ 9.473599] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 qu
[ 9.474469] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 9.474741] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus numbe
[ 9.474857] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[ 9.475258] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bc
[ 9.475369] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=
[ 9.475464] usb usb1: Product: xHCI Host Controller
[ 9.475549] usb usb1: Manufacturer: Linux 6.6.40 xhci-hcd
[ 9.475635] usb usb1: SerialNumber: 0000:00:14.0
[ 9.476684] hub 1-0:1.0: USB hub found
[ 9.476833] hub 1-0:1.0: 6 ports detected
[ 9.481218] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bc
[ 9.481355] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=
[ 9.481455] usb usb2: Product: xHCI Host Controller
[ 9.481541] usb usb2: Manufacturer: Linux 6.6.40 xhci-hcd
[ 9.481627] usb usb2: SerialNumber: 0000:00:14.0
[ 9.482411] hub 2-0:1.0: USB hub found
[ 9.482561] hub 2-0:1.0: 1 port detected
[ 9.721260] usb 1-3: new high-speed USB device number 2 using xhci_hcd
[ 9.847523] usb 1-3: New USB device found, idVendor=1a40, idProduct=0101, bcd
[ 9.847638] usb 1-3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 9.847734] usb 1-3: Product: USB 2.0 Hub
[ 9.849727] hub 1-3:1.0: USB hub found
[ 9.849900] hub 1-3:1.0: 4 ports detected
[ 9.965266] usb 1-4: new full-speed USB device number 3 using xhci_hcd
[ 10.092440] usb 1-4: New USB device found, idVendor=1a86, idProduct=7523, bcd
[ 10.092556] usb 1-4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 10.092652] usb 1-4: Product: USB Serial
[ 10.270266] usb 1-3.1: new full-speed USB device number 4 using xhci_hcd
[ 10.459567] usb 1-3.1: New USB device found, idVendor=1a86, idProduct=7523, b
[ 10.459680] usb 1-3.1: New USB device strings: Mfr=0, Product=2, SerialNumber
[ 10.459777] usb 1-3.1: Product: USB Serial
[ 10.638272] usb 1-3.2: new high-speed USB device number 5 using xhci_hcd
[ 10.839353] usb 1-3.2: New USB device found, idVendor=2c7c, idProduct=0316, b
[ 10.839468] usb 1-3.2: New USB device strings: Mfr=1, Product=2, SerialNumber
[ 10.839563] usb 1-3.2: Product: RG255C-GL
[ 10.839646] usb 1-3.2: Manufacturer: Quectel
[ 10.839728] usb 1-3.2: SerialNumber: ad1ad481
[ 25.108263] ata1: SATA link down (SStatus 0 SControl 300)
[ 25.164248] ata1: limiting SATA link speed to 1.5 Gbps
[ 25.476264] ata1: SATA link down (SStatus 0 SControl 310)
[ 25.532159] ata1: limiting SATA link speed to 1.5 Gbps
[ 25.844261] ata1: SATA link down (SStatus 0 SControl 310)
[ 25.900663] ata1: limiting SATA link speed to 1.5 Gbps
[ 26.212263] ata1: SATA link down (SStatus 0 SControl 310)
[ 26.268711] ata1: limiting SATA link speed to 1.5 Gbps
[ 26.580262] ata1: SATA link down (SStatus 0 SControl 310)
[ 26.636638] ata1: limiting SATA link speed to 1.5 Gbps
[ 26.948261] ata1: SATA link down (SStatus 0 SControl 310)
[ 27.004903] ata1: limiting SATA link speed to 1.5 Gbps
[ 27.316264] ata1: SATA link down (SStatus 0 SControl 310)
[ 27.372502] ata1: limiting SATA link speed to 1.5 Gbps
[ 27.684262] ata1: SATA link down (SStatus 0 SControl 310)
[ 28.508266] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 28.508762] ata2.00: supports DRM functions and may not be fully accessible
[ 28.511130] ata2.00: supports DRM functions and may not be fully accessible
[ 28.513061] ata2.00: configured for UDMA/133
[ 28.884262] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 28.884756] ata2.00: supports DRM functions and may not be fully accessible
[ 28.887078] ata2.00: supports DRM functions and may not be fully accessible
[ 28.889048] ata2.00: configured for UDMA/133
[ 29.252265] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 29.252757] ata2.00: supports DRM functions and may not be fully accessible
[ 29.255082] ata2.00: supports DRM functions and may not be fully accessible
[ 29.257008] ata2.00: configured for UDMA/133
[ 29.629263] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 29.629754] ata2.00: supports DRM functions and may not be fully accessible
[ 29.632118] ata2.00: supports DRM functions and may not be fully accessible
[ 29.634051] ata2.00: configured for UDMA/133
[ 29.996266] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 29.996759] ata2.00: supports DRM functions and may not be fully accessible
[ 29.999126] ata2.00: supports DRM functions and may not be fully accessible
[ 30.001053] ata2.00: configured for UDMA/133
[ 30.365263] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 30.365755] ata2.00: supports DRM functions and may not be fully accessible
[ 30.368124] ata2.00: supports DRM functions and may not be fully accessible
[ 30.370049] ata2.00: configured for UDMA/133
[ 30.732265] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 30.732760] ata2.00: supports DRM functions and may not be fully accessible
[ 30.735129] ata2.00: supports DRM functions and may not be fully accessible
[ 30.737054] ata2.00: configured for UDMA/133
[ 32.000371] FAT-fs (sda3): bogus number of reserved sectors
[ 32.000480] FAT-fs (sda3): Can’t find a valid FAT filesystem
[ 33.403934] 8021q: adding VLAN 0 to HW filter on device eth0
[ 36.433816] igb 0000:03:00.0 eth0: igb: eth0 NIC Link is Up 1000 Mbps Full Du
[ 38.884263] 8021q: adding VLAN 0 to HW filter on device eth1
[ 44.358649] 8021q: adding VLAN 0 to HW filter on device eth2
[ 58.126640] qmi_wwan_q: loading out-of-tree module taints kernel.
[ 58.131492] qmi_wwan_q 1-3.2:1.3: cdc-wdm0: USB WDM device
[ 58.131948] wwan wwan2: port wwan2qmi0 attached
[ 58.133405] qmi_wwan_q 1-3.2:1.3: Quectel RG255C-GL work on RawIP mode
[ 58.133934] qmi_wwan_q 1-3.2:1.3: rx_urb_size = 16384
[ 58.134726] qmi_wwan_q 1-3.2:1.3 wwan2: register ‘qmi_wwan_q’ at usb-0000:00:
[ 58.134950] usbcore: registered new interface driver qmi_wwan_q
[ 63.237566] net wwan2: ul_data_aggregation_max_datagrams=11, ul_data_aggregat
[ 63.620845] net wwan2: link_state 0x0 → 0x1
[ 72.142827] xt_ndpi v1.2 ndpi 4.9.0 IPv6=YES debug_message=no
Maybe this is the reason why it is wwan2 but not wwan0.
I don’t know why there is wwan0 and wwan1 even there is no Quectel modem. Please check it on your own.
