@silvia Hi, I have the same problem. Can you send me the related AT commands and right version?
Thank u in advance!
Yunus
Thank u in advance!
Yunus
Dear @Yunus_As
What is your problem? Can’t connect SA or others?
Device/FW: Quectel RG255C-GL (5G RedCap) on Linux with qmi_wwan_q (Quectel) driver.
SIM/PLMN: 286-03 (Türk Telekom).
Status: LTE (4G) attaches and passes data. 5G cannot attach.
My Command Set:
AT+CPIN? → +CPIN: READY
AT+CFUN? → +CFUN: 1
AT+C5GREG=2 → OK (URC enabled)
AT+QNWPREFCFG=“nr5g_band” → … 1:3:7:20:28:40:41:71:77:78:79
AT+QNWPREFCFG=“mode_pref”,NR5G → OK (NR-only preference)
AT+COPS=1,2,“28603”,12 → +CME ERROR: 30
AT+C5GREG? → OK +C5GREG: 2,0
Dear @Yunus_As
Do you know which band of SA on your region?
n77 or others?
It is n78 .
Firmware: RG255CGLABR01A04M4G
Hi @silvia
I am also having issues connecting to 5G SA with Quectel RG255C-GL
Band is n78
What are the AT commands necessary?
Thanks!
Dear @ArtV
Good day Madam,
Band is n78
Thanks!
Dear @ssss
Could you please share these AT commands with me as well?
I’m having a very similar issue with the Quectel RG255C-GL.
AT+QGMR
RG255CGLABR01A04M4G_A0.003.A0.003
AT+COPS?
+COPS: 0,0,“LMT”,7
+QNWPREFCFG: “mode_pref”,AUTO
+QNWPREFCFG: “nr5g_band”,1:3:7:8:20:28:78
AT+QENG=“servingcell”
+QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,247,01,4F4E10,180,2850,7,5,5,9CEB,-84,-10,-54,13,0,-,29
+QNWPREFCFG: “mode_pref”,NR5G
AT+COPS=?
+COPS: (1,“LV LMT”,“LMT”,“24701”,12),(1,“LV LMT”,“LMT”,“24701”,7),(3,“BITE LV”,“BITE LV”,“24705”,7),(3,“Tele2 LV”,“Tele2 LV”,“24702”,7),(1,“247 06”,“247 06”,“24706”,7),(0-4),(0-2)
+QENG: “servingcell”,“LIMSRV”,“NR5G-SA”,“FDD”,247,01,013D39B59,213,C3FB,154570,28,1,-61,-11,6,0,66
AT+COPS=1,2,“24701”,12
+CME ERROR: no network service
AT+CGDCONT?
+CGDCONT: 1,“IP”,“internet.lmt.lv”,“0.0.0.0”,0,0,0,0,“”,0
+CGDCONT: 2,“IPV4V6”,“ims”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0,“”,0
+CGDCONT: 3,“IPV4V6”,“sos”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,1,“”,0
AT+QSCAN=2
+QSCAN: “NR5G”,247,01,154570,28,-62,-11,66,1
Dear @Vadim_Ipatov
It is a different issue.
Your firmware is old, I will send newer to your email, please try again.
Hi, I’m having similar issues as described here. Version RG255CGLABR01A04M4G_A0.300.A0.300
The cell is n40 and configured with 20MHz. There’s no issue when connecting to n28 or n1 even with the RedCap compatibility flag disabled on the gNodeB. Traces from the node show no registration attempt has been made. Could you please advise on the steps to solve the issue? Thanks.
Dear @Alentejana
Hi, I have similar problem. Version RG255CGLABR01A04M4G_A0.300.A0.300
AT+C5GREG?
+C5GREG: 0,0
AT+C5GREG?
+C5GREG: 0,0
AT+CFUN?
+CFUN: 1
ERROR
AT+QENG=?
+QENG: (“servingcell”,“neighbourcell”)
+QENG: “servingcell”,“SEARCH”
Dear @Safel
Do you also test with private network?
Please share information, band, bandwidth.
Hello @silvia,
I’m using the 5G REDCAP EVB - RG255C-GL, and Could you please give me the backup & restore of existing firmware from device & required documentation and tools. Is there any Linux tool available or only windows for backup and restore?
This is my device information:
AT
AT+CVERSION
VERSION: RG255CGLABR01A04M4G
Jun 24 2024 15:04:10
Authors: Quectel
AT+CSUB
SubEdition: V02
AT+QGMR
RG255CGLABR01A04M4G_01.002.01.002
Also could you please give the updated firmware for this? and how we can enable the adb & debug-logs for this? As existing firmware not shows option for this:
AT+QCFG=?
+QCFG: "rrc",(0-5)
+QCFG: "pdp/duplicatechk",(0,1)
+QCFG: "risignaltype",("respective","physical")
+QCFG: "lte/bandprior",(1-43),(1-43),(1-43)
+QCFG: "diversity/config",(0,1),(1,2),(0)
+QCFG: "div_test_mode",(0,1)
+QCFG: "usbnet",(0-3)
+QCFG: "data_interface",(0,1),(0,1)
+QCFG: "pcie/mode",(0,1)
+QCFG: "wifi/model",("fc60e","fc08e")
+QCFG: "sms_control",(0,1),(0,1)
+QCFG: "call_control",(0,1),(0,1)
+QCFG: "netmaskset",(0,1)[,<netmask>]
+QCFG: "clat",(0,1),(0,1),<prefix>,(0,32,40,48,56,64,96),<fqdn>,(0,1),(0,1,2,4,8),(0,1),(0,1),(0,1,2),(0,1,2)
+QCFG: "ntp",(1-10),(5-60)
Thank You.
Dear @Rohit_Jagtap
I have replied in another topic, please check.
