Quectel module returning AT+QSTAT: 0,1
I am currently working with the Quectel EC200UCNAP-N05-SGNSA module and facing an issue while establishing and maintaining an MQTT connection to our server.
Problem Description:
  • The MQTT connection is established successfully.
  • Upon publishing the registration packet, the module often disconnects from the server immediately afterward.
  • In certain cases, the registration packet is successfully delivered to the server, yet the module still responds with +QMTSTAT: 0,1.
  • I have already configured the keep-alive interval using:
AT+QMTCFG=“keepalive”,0,120
Current Command Sequence:
mqtt_commands_t Registration_buff[BUFFER_SIZE_30] = {
e_mqtt_check_sim_sts, // Check SIM status
e_mqtt_check_ntwrk_sts, // Check network registration
e_mqtt_keepalive, // Set keep-alive
e_mqtt_check_ntwrk_band, // Check network band
e_mqtt_check_signal_strngth,// Signal strength
e_mqtt_rqst_imei, // IMEI
e_mqtt_rqst_imsi, // IMSI
e_mqtt_open_st05, // MQTT open
e_mqtt_keepalive,
e_mqtt_connect_st05, // MQTT connect
e_mqtt_snd_reg_packet, // Publish registration packet
e_mqtt_close,
e_mqtt_open_st05,
e_mqtt_subscribe, // Subscribe to topic
e_mqtt_close
The response is:
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,1
AT+QENG=“servingcell”
+QENG: “servingcell”,“NOCONN”,“LTE”,“TDD”,404,45,AD69901,400,39125,40,4,4,2162,-130,-16,-96,36,-
AT+CSQ
+CSQ: 8,99
AT+CGSN
867950072779232
AT+CIMI
404450660781137
AT+QMTOPEN=0,“server_link”,1884
AT+QMTCONN=0,“clientID”,“usrname”,“password”,
+QMTCONN: 0,0,0
AT+QMTPUBEX=0,0,0,0,“Name/867950072779232/METADATA_SYNC”,69
{“date_time”:1747295948000,“ic_imei”:“867950072779232”,“version”:0}
+QMTPUBEX: 0,0,0
AT+QMTCLOSE=0
ERROR
AT+QMTOPEN=0,“server”,1884
+QMTOPEN: 0,0
AT+QMTCONN=0,“client id”,“usrname”,“password”,
+QMTCONN: 0,0,0
AT+QMTSUB=0,1,“name/867950072779232/METADATA_SYNC_ACK”,0
ERROR
+QMTSTAT: 0,1
Could you please help investigate:
  1. Why the module is getting disconnected after QMTPUBEX, even with a successful publish?
  2. If any timing or sequence issue exists in the current flow.
  3. Whether additional configurations (e.g., QoS, retry handling, connection persistence) are required.
  4. If there are module-specific recommendations for weak signal conditions during MQTT operations.
  • The server is expected to send three acknowledgements upon receiving the metadata.
  • However, the connection is dropped before acknowledgements are received.
  • Signal strength is around CSQ: 8,99 (marginal but connected).
Thank you.
Hi ,
Please try changing the last parameter of this AT command to 1 or 2
