We have so far used the Quectel EC25AFA via USB with a Raspberry Pi 4 using ModemManager and NetworkManager. We’re now looking to embed the modem and use the UART interface instead of USB. We have a working UART connecting, and the modem responds correctly to AT commands on the UART. However, neither ModemManager nor NetworkManager can detect the modem.
Out hardware setup:
- Quectel UART_RX → RPi GPIO8 (UART 4)
- Quectel UART_TX → RPi GPIO9 (UART 4)
- Quectel UART_CTS → RPI GPIO11
- Quectel UART_RTS → RPI GPIO10
We’ve set the following udev rules in sudo nano /etc/udev/rules.d/99-ttyAMA4-modem.rules :
# Rule for ModemManager to handle the Quectel modem on ttyAMA4
ACTION=="add|change", SUBSYSTEM=="tty", KERNEL=="ttyAMA4",
ENV{ID_MM_CANDIDATE}="1",
ENV{ID_MM_TTY_BAUDRATE}="115200",
ENV{ID_MM_TTY_FLOW_CONTROL}="rtscts"
However, mmcli -L returns No modems found
Similarly, using NetworkManager sudo nmcli device connect ttyAMA4 returns Error: Device 'ttyAMA4' not found.
My question is: Is it possible to use the EC25 UART with ModemManager/NetworkManager? If so, is there any documentation on how to do this?
