Hi @vpaulo
You can refer to this document.
Quectel_LTE_Standard_FILE_Application_Note_V1.1.pdf
Can I have latest firmware for EC25-E EC25EFAR06A06M4G?
I’m looking for EC25EFAR06A17M4G_20.200.20.200 firmware or later.
I’m trying to debug some issues with EC25EFA and OpenWRT:
- Modem won’t accept empty PIN;
- Once modem had an error with empty PIN, it won’t accept any other PIN before power cycling.
Current firmware is:
root@rt0:~# qmicli --device=/dev/cdc-wdm0 --dms-get-revision
[/dev/cdc-wdm0] Device revision retrieved:
Revision: 'EC25EFAR06A02M4G'
Could you provide asked or newer version, please? I’d like to differentiate between old firmware issues and possible OpenWRT bug. I’ve seen jitter.nl were mass updating to said version, so I assume it is stable enough.
Hi @lyman.Q can you share the latest firmware?
My model: EC25EFAR06A04M4G
EC25-E
Hi @lyman.Q, I also need firmware for the EC25E.
VERSION: EC25EFAR06A17M4G
Jun 25 2023 19:37:22,
with this firmware it does not want to register on the network.
Hello, I have EC25-EUX with firmware EC25EUXGAR08A13M1G_20.200.20.200
If there is a more current vesion of this firmware, may I please receive i?
Can I have the EC25-EU firmware, flash guide or flash tools and the windows driver?
Hi, I have a EC25-EU with the following firmware: EC25EUGAR06A07M4G_01.001.01.001
Could we please get the latest one, if there is one available?
Hello, would it be possible to get the latest firmware for this module: EC25ECGAR06A13M1G
Thanks in advance!
I actually accidentally put one of my modem in Download mode. FIrmware was EC25ECGAR06A13M1G_20.002.20.002 . Can you etiher provide me with a firmware for this module (either the latest or this one) or tell how to exit Download Mode withe Qfirehose?
Regards
RM520N-GL
Curently we have M520NGLAAR01A05M4G
Best regards,
I am having EC25-E with revision EC25EFAR06A08M4G
can you please mail me latest firmware file
Regards
Praveen
Could I also get the latest firmware for EC25E?
I need the firmware of EC25-E. The current version is EC25EFAR06A08M4G. I can get the latest firmware. Can you send it to me?
First, thank you
can I have the latest firmware too?
Thanks.
Hi!
Can I have the latest firmware too?
Thanks!!
AT+QGMR
EC25EFAR06A06M4G_01.006.01.006
Please share the latest firmware and the tools to flash (preferably from linux).
If there is a more current vesion of this firmware, may I please receive it?
Hello again,
I am currently running into issues with our ec25-e modems. I noticed they are on different versions. The lowest one i found:
EC25EFAR06A16M4G_20.200.20.200
Can you provide latest stabel firmware?
I would like to update EC25-E and EC21-E to the latest FW release.
Currently (AT+QGMR) these are the installed fw versions:
EC25EFAR06A08M4G_01.007.01.007
EC21EUXGAR08A06M1G_20.002.20.002
I need also the “release notes” document of both the FW versions, please.
Thanks in advance,
Best regards,
AG
