Hi Herbert,
EC25EUGAR06A05M4G_01.005.01.005
EC25EFAR06A08M4G_01.007.01.007
Thanks !
Hi Herbert,
Thanks !
I have sent them to your email,pls chk
Hi Herbert, well received, thanks !
Could you please also send me the QFireHose tool for Linux (from what I understood that is what is to be used to flash the firmware).
Thanks again !
I have sent it to your email,pls chk
Could you send me the latest firmware for my Quectel EC25-EU & flashtools?
AT+QGMR
EC25EUGAR06A06M4G_01.005.01.005
I am having also a random issue with my module, that in the past was solved my upgrading the firmware.
Sometimes the module restarts on its own.
My chipset is EC25EFA
I currently have EC25EFAR06A09M4G . Could you please send me the latest version?
Denis
Hi can you share with me the latest firmware and tools to update them. I have a test unit that always hangs once or twice a day that requires a reboot of the system to gain back access to it. I hope that a newer firmware would be better. thanks. Here are the details from my unit:
ati
EC25
Revision: EC25EFAR06A03M4G
ati+qgmr
EC25
EC25EFAR06A03M4G
AT+QGMR
EC25EFAR06A03M4G
thanks for providing the latest firmware. I’ve updated is successfully using the QFirehose tool. But now the E25-E behaves like the new EC25-EUX that i have. I’m getting this error in ubuntu LTS 20.
qmicli --device=/dev/cdc-wdm1 --device-open-proxy --uim-get-card-status
[13 Oct 2023, 01:55:06] -Warning ** [/dev/cdc-wdm1] MBIM error: NoDeviceSupport
error: couldn’t create client for the ‘uim’ service: CID allocation failed in the CTL client: Transaction timed out
On the older firmware as a comparison:
[/dev/cdc-wdm1] Successfully got card status
Provisioning applications:
Primary GW: slot ‘1’, application ‘1’
Primary 1X: session doesn’t exist
Secondary GW: session doesn’t exist
Secondary 1X: session doesn’t exist
Slot [1]:
Card state: ‘present’
UPIN state: ‘not-initialized’
UPIN retries: ‘0’
UPUK retries: ‘0’
Application [1]:
Application type: ‘usim (2)’
Application state: ‘ready’
Application ID:
A0:00:00:00:87:10:02:FF:60:F0:01:89:00:00:01:FF
Personalization state: ‘ready’
UPIN replaces PIN1: ‘no’
PIN1 state: ‘disabled’
PIN1 retries: ‘5’
PUK1 retries: ‘10’
PIN2 state: ‘enabled-not-verified’
PIN2 retries: ‘3’
PUK2 retries: ‘10’
Do you know a fix to this? if not, can you provide an older version of the firmware that i can downgrade to if that is possible?
Thanks again.
Herbert, can you share with me the older firmware please EC25EFAR06A03M4G.
i need to downgrade to this firmware.
Thanks again.
@herbert.pan-Q Can you send me the last firmware for the EC-25EUX
AT+QGMR?: EC25EUXGAR08A05M1G_01.001.01.001
Hi Herbert,
Please share with us the link to download a firmware for EC25-E that supports eSIM.
I captured from AT Command Window / current firmware version.
at+QGMR
EC25EFAR06A04M4G_01.004.01.004
at+qesim=“list”
ERROR
Give us the download link for QFlash Tool to flash the firmware that supports eSIM.
Thanks.
Regards,
Sivakumar
Thanks for sharing the firmware / flash tool. We upgrade to the new firmware version in EC25-E.
ATI
EC25
Revision: EC25EFAR06A17M4G
When we try to access QSIM module in EC25-E, it is reporting ERROR.
AT+QESIM=?
ERROR
AT+QSIM=“eid”
ERROR
Please let us know if it is the correct firmware version to enable eSIM function or if you need to enable a specific AT command.
Thanks.
Regards,
Sivakumar
Could i get the Last FIRMWARE for EC25-E?
Please can you share the latest EC25-E firmware? I have not received it in email as you notified me (neither in spam folder). Thanks a lot in advance for your help and support.
Kind regards,
Vit Janeba
