Thank you !
Can you also send me recent EC25 Series eSIM
AT Commands Manual ?
I have sent it to you,pls check,I hope you can click the for me,thanks
Hi @herbert.pan-Q,
I have some EC25-EFA (MiniPCIE) running on Raspberry Pi & and LTE Hat. Can I have the latest FW for those devices ? And also the tool that I can use to flash them from the Raspberry Pi ?
Current FW is EC25EFAR06A08M4G_01.007.01.007
BR,
Mathieu F.
I have sent the latest firmware and upgrade tool to you,pls check,I hope you can click the for me,thanks
Thanks for your answer. I’ve got another EC25-E devkit on my desk, currently running EC25EFAR08A04M4G_20.001.20.001 version.
Can I update with the same FW you’ve shared (EC25EFAR06A20M4G_20.200.20.200) or should I get another FW version to udpate this board ?
BR,
Mathieu F.
I have sent the R08 firmware and upgrade tool to you,pls check,I hope you can click the for me,thanks
Hi, Can I have latest firmware for my EC25-E. Now it’s using EC25EFAR06A11M4G. And I also encounter with “CME ERROR: 3” when try to restart modem using “AT+CFUN=1,1” command.
Hey, could I get the most recent firmware for EC25EUGAR06A04M4G_01.004.01.004?
I have sent the latest firmware to you,pls check,I hope you can click the for me,thanks
ERROR 3 is usually caused by communication with the UART, it is recommended that you use USB to try
Hello support,
Can I get the latest firmware for EC25
EC25EFAR06A11M4G_01.001.01.001
ATI
EC25
Revision: EC25EFAR06A11M4G
I’ll need an instructions/tools to flash it on arm7 Linux (a custom Allwinner board)
Thanks in advance!
Best wishes,
Atanas
Thanks for provided firmware files.
Could you please give me an instructions/guide on how the new firmware should be applied?
Best wishes,
Atanas
Hi Support,
Can I get the latest firmware for EC25EFA,
Current I have: EC25EFAR06A10M4G
Thank You
Best Regards from Poland
//Piotr.
@herbert.pan-Q thank you so much.
But the package you sent seems to be for Windows while I need to flash the firmware under Linux OS.
Do you have a tool for flashing the firmware under Linux?
Thanks in advance,
Atanas
Hello!
Can You send for me the new firmware please? EC25EUGAR06A04M4G installed now
(post deleted by author)
@herbert.pan-Q could you send me the latest firmware for ec-25-e? My current revision: EC25EFAR06A03M4G
