So im trying to get the BG95-M9 to work with the EVB but when im using the automatic initialization i get the following error msg
We would really like to use Quectel for our future applications but unfortunaly we are new to this market and therefore unfamiliar with the technology or what could cause this problem.
Kind regards,
Dominik Grimm
I suggest you add a AT command and execute them multiple times
AT+QENG=“servingcell”
AT+CGPADDR
Even after multiple repetitions the result of these to commands is as follows:
By providing the Log, BG95 has successfully registered with the network and successfully obtained the IP, you can test QPING
Thank you i will try that as soon as possible but i have another question
Does the BG-M9 Chip support 450MHz like the M4?
Because as you can see it is absent in this picture
You can check the hardware manual for instructions
