We are using the Quectel BC66OK-GL module with a Hologram sim. We have no problem with operation in the US, but trying to get it to work in Europe. The Hologram sim supports roaming and we have a data plan for Europe, but cant seem to get it to work. We believe the Quectel device does NOT have roaming enabled, but it is not clear how to enable roaming, can you please confirm roaming should work and how to enable it?
Roaming is already enabled on the BC660K by default, and you will need to check if your SIM card has a roaming agreement with the carrier in the roaming region
